Sticky Trim Indicators >
Old 06-22-2004 | 08:55 PM
Ed
Default Re: Sticky Trim Indicators
Most Throttle/Shift/Indicator cables have the length(sometimes indicated in inches) printed at either ends or both ends of the cables. Simply replace with the same length cable. Been doing it this way for 25 years. Ed
Ed is offline
Old 06-22-2004 | 09:23 PM
Thanks Ed. But my boat does not have any indicator cables now, as it has never had mechanical indicators before. This is something I want to add to it.
When I go to replace the shift and throttle cables, I will look for the measurements as you suggested, but in the mean time, I hope a 311 owner can help with the transom-indicator gauge measurement.
Chart is offline
Old 06-22-2004 | 09:55 PM
cuda's Avatar
Chart, as you pointed out, mine would probably be different due to the Kaama drives.
cuda is offline
cuda's Avatar
Where the hell is Audio anyway!
cuda is offline
Old 06-22-2004 | 10:50 PM
fyi...
http://www.rexmar.com/page85.html
http://www.bluewaterperformance.com/activators.htm
jackhammer is offline
Old 06-23-2004 | 08:43 AM
mr_velocity's Avatar
I never had any luck with these indicators, they always stuck. Since I never have to trim my drives to tailer position I did the following. I drilled the end of the plastic rod that slides in the tube. I then took the clamp pictured below and drilled a hole in that. I screwed the clamp into the end of the rod and fixed it loosely around the the stainless piece that pushes the rod in. Now the drive pulls the rod out and pushes it back in. The sping and gunk are now along for the ride. Did this first in 1988 on my Baja.
Just make sure the clamp has a nylock nut on it so it doesn't tighten up too much or loosen.
mr_velocity is offline
Frank Galasso
Do It Yourself, Boating on a Budget
2
02-06-2008 08:22 PM
blefever
3
01-10-2008 08:13 PM
truckone
01-23-2006 12:47 PM
Monty
4
06-29-2005 01:14 PM
Audiofn
06-16-2002 09:49 AM
