thermostat install >
thermostat install
thermostat install
Old 06-24-2004 | 04:48 PM
Default thermostat install
I saw a couple earlier posts regarding this but still had a few questions. OK I have an 89 454 mag with I guess the earlier thermostat housing. (6 outlet).
Can I use the blue-style fel-pro gasket material and make them myself? Also how would Hylomar work in this type of application? Would you apply any sealant to the cork gasket or is that not done? Anything I am missing? THanks again!
challenger454 is offline
Old 06-24-2004 | 05:24 PM
Fightclub
Default Re: thermostat install
______________________________
Just did this and NO do not make your own Gasket, they are around 5.00 or less depending on where you get them. You MUST clean the surfaces to get a good seat it can be a PITA but needs to be done. Follow these links for parts.
http://www.mercruiserparts.com/selec...doc_nbr=+19378
Good luck, its an easy job I know because I did it.
fightclub.
Old 06-25-2004 | 12:52 PM
dyno's Avatar
Charter Member #655
Brad you coming down for SOTW??? I'll be up in your neck of the woods (Elkrapids) soon...July 12-18 and August 9-15
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
nocigarette
4
06-19-2006 09:53 PM
boatnt
2
02-13-2006 06:55 AM
Rambunctious
5
05-17-2004 12:20 PM
Perfectmix
9
05-06-2004 08:32 PM
Speed H2O
6
12-19-2002 12:45 PM
