What prop do I need?
I the middle of a motor change and I need help with a starting point for a prop.
502, 550hp carb motor
Bravo 1.50 gears
25 Checkmate, not sure of the weight
Bravo 1.50 gears
I run a 25 Hydromotive on a 251 convinsor. The hydromotives seem to work better on the checkmate's as far as stability and ride. Good luck. PM me if you want to talk about specifics. Dave
Originally Posted by Aggressor 25
What is your Max RPM (rev limiter) going to be set at?
Ty
Ty
Rev limiter??? What's that?
I bought a used T-bolt system (Dist, harness, module) for this thing and it wasn't part of the deal. I do know they are high dollar from Merc.
I know I will need one too save the motor during air time but is it necessary for the ignition system to work? I would like to get the boat wet again before the end of July
Send a message to [email protected]
Eric Garrett, very good friend of mine, formerly here on the Potomac, now lives in TX.
They had a 1989 Checkmate 251, with 500HP, bumped up to 565HP.
I am pretty sure his favorite was a worked 28 Hydromotive.
MIKEHTMSR24
07-22-2002 03:18 PM
