TRS how many Horseys >
Old 08-05-2004 | 07:15 AM
J-Bonz's Avatar
Default Re: TRS how many Horseys
I told you at the casino the only bottom you can mate with a trs upper is a #2 Lower which the parts are NA. If I am wrong some one please correct me.
Good Luck my brotha,
Jack Jr.
J-Bonz is offline
Old 08-05-2004 | 08:02 AM
Whats up Jack?? I never realized you were even on this site until this weekend.....forgot to ask your screen name
btw, thanks for the tour of the boat....I am totally stuck on having a Mistress now
THRILLSEEKER is offline
Old 08-05-2004 | 08:24 AM
Panther's Avatar
Frank's Marine Service
I would say 550HP is about right.
I also have a good friend who "solid shim's" the bearing carrier on the right hand rotation drives. From his experience it has been the best way to keep the drives together.
The reason the drives blow is the bearing carrier get's pushed forward because there is a crush collar that is used to set bearing pre-load. When it is solid shimmed, there is no play. I gave it a shot, but it takes a lot of time to shim it properly to set the right pre-load. I got frushtrated and just rebuilt the drive to merc specs.
Panther is offline
GoFastSonic
Classic Offshore
8
05-12-2008 09:48 AM
overdrive75
Drives and Lower Units
1
09-11-2007 01:50 PM
Pantera24
9
05-24-2007 02:57 PM
jeff1000man
02-27-2007 09:45 AM
