Bravo 1 wont go up while going high speed >
Old 09-21-2004 | 08:12 PM
migara422's Avatar
Default Re: Bravo 1 wont go up while going high speed
After going crazy with this i found i was running an alfa ram and i bravo ram, bought a new ram and i hoped the problem was solved but not, im trying to find the cause of this and maybe i found it, on the selenoids there is a green and blue wire, when i jumped the selenoid that had the blue wire my drive went down and of course when i jumped the one with green it went up. I guess the lines are wrong and hope this could be the problem finally?
migara422 is offline
Old 09-21-2004 | 08:28 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
If the wires where just reversed, wouldn't the switch just work backwards and not explain why the drive works fine under 30 mph and not over 30? Sounds more like a hyd problem, either leaking ran or pump issues. Just thinking out loud here.
US1 Fountain is offline
Old 09-22-2004 | 11:27 AM
migara422's Avatar
Is that true thought? someone here said that the circuits were different and up would be alot higher than down, i hope to solve this problem soon.
Old 09-22-2004 | 06:53 PM
Blue is up for sky and Green is down for grass. Sounds like the lines are reversed and the switch is in mounted wrong. Swap lines and and flip the switch and I bet it works fine.
BadDog is offline
Old 09-22-2004 | 09:16 PM
migara422's Avatar
Does having the lines backwards would make any difference in the way the pump works trimming up? i get a mix of answers, one says makes no difference if the wires are crossed and some say it affect the trim up, hope someone that had this problem would post here.
Old 09-25-2004 | 04:47 PM
Had same problem.Lines on pump were reversed
cafeman is offline
Old 09-25-2004 | 09:54 PM
migara422's Avatar
Thanks for the info guys, I hope to try the trim monday now that i reversed the lines, unless this fing hurricane doesnt destroy my boat, im right in the eye path of this storm, but hell i guess it could be worse.
Carlos
boatfreak
Active Thunder
19
02-26-2008 09:50 PM
pachanga
Insurance and Finance
4
02-20-2008 09:51 PM
switzer master
Drives and Lower Units
20
06-21-2007 08:20 AM
Jamie B.
5
08-10-2002 10:36 PM
