More HP for HP 500 >
More HP for HP 500
More HP for HP 500
Old 09-17-2004 | 08:27 PM
  #41
Strip Poker 388's Avatar
Rob
Default Re: More HP for HP 500
Originally Posted by klaw
if you use the CMI with the flex flairs the tail pipe has some adjustability. If you buy a used set even if they are the cool collar design make sure the tail pipe connection is the flex flair design the one they make for Mercury are not.
Mine is the merc style . Flat flange ,Like a collector gasket on a car. So the little hose at the transom will not be enough ajustment
Strip Poker 388 is offline
Old 09-17-2004 | 09:07 PM
  #42
WAGS382's Avatar
Strip Poker 388
I have a friend here in Ohio who can modify your tail pipes if you want to go that route, he is very good and reasonable. Jeff
WAGS382 is offline
Old 06-28-2015 | 12:48 PM
  #43
Im interested in doing the same thing to my rebuilt 502
Its a 502 bored 0.030 over with CMI exhausts and has 9.1 CR
Was interested in the Dart 308 steel heads cause I use the boat in salt and the 741 Cam.....
What do you guys think about this combo ????. How much HP and Torque will it make ????
louisfever is offline
Old 06-28-2015 | 06:20 PM
  #44
Originally Posted by louisfever
im interested in doing the same thing to my rebuilt 502
its a 502 bored 0.030 over with cmi exhausts and has 9.1 cr
was interested in the dart 308 steel heads cause i use the boat in salt and the 741 cam.....
What do you guys think about this combo ????. How much hp and torque will it make ????
575-600hp.
MILD THUNDER is offline
Old 06-28-2015 | 09:58 PM
  #45
I did it...
http://www.offshoreonly.com/forums/d...02-w-afrs.html
(Well, Marine Kinetics [Bob] & Unlimited Offshore Marine [Jamie] did - I just paid.)
242LS is offline
Old 06-29-2015 | 08:09 AM
  #46
Here's another I found while doing a search
http://www.offshoreonly.com/forums/g...out-hp500.html
endeavor1 is offline
mgocean
6
03-07-2006 11:56 AM
Secretformula
06-09-2003 04:50 PM
dreamer
05-23-2003 04:06 PM
florida gator
01-17-2003 10:41 AM
rssteiny
1
08-05-2002 07:24 PM
