Can't get the friggin ink of my sunpad!!! >
Old 09-02-2004 | 07:44 PM
Jigsaw89's Avatar
Default Re: Can't get the friggin ink of my sunpad!!!
I suggest you try CRC Brakleen brake cleaner with a mildly abrasive scrub pad.
Jigsaw89 is offline
Old 09-02-2004 | 07:48 PM
Wow, keep the ideas coming. Will try them all on my test piece and go from there.
BadDog is offline
Old 09-02-2004 | 07:57 PM
Dave M's Avatar
Veteran: Navy
You have to fight the "chick stuff" with chick stuff. Try nail polish remover. I had a spot I could not get out. The wife suggested nail polish remover and it worked! No damage to vinyl.
Dave M is offline
Old 09-02-2004 | 08:18 PM
bowtie's Avatar
The bourbon should work. The more you drink the less you'll see.
bowtie is offline
Old 09-02-2004 | 08:27 PM
Try using some Goop, i think Lowes sells it. The press and bindery people use it to remove the ink from their hands at the printing co. i worked at.
Jim
kaamaman is offline
Old 09-02-2004 | 08:36 PM
Nail polish remover is diluted and scented acetone. --- JP
jpclear is offline
Old 09-02-2004 | 08:38 PM
When I was having a motor done for an old boat of mine, I had a notepad with a bunch of notes on it and left it ink side down on my back seat. Then I forgot about it and it got wet and left everything I wrote down stained into the seat. I tried everything like you but I ended up quitting and eventually the sun took it out. I don't know how but over time it should fade away.
Dangerous Dave is offline
Old 09-02-2004 | 09:08 PM
toonatime
Try Marine cleaner wax in circular motion. Have removed some large pen marks with this..
Old 09-02-2004 | 10:24 PM
Rubbing alcohol will usually remove ink and permanent marker.
Active Mike is offline
Old 09-03-2004 | 07:34 AM
I,ve used RaceGlaze for scuff marks on the back seat, probably from someone wearing sandles or sneakers. It worked well. Dog's marks may have penetrated the pores of the vinyl. Worth a try though.
Dog, don't waste too much good bourbon!!
Kidnova is offline
