HP 500's
Old 11-23-2004 | 10:54 AM
kevinr's Avatar
Registered User
Default Re: HP 500's
Originally Posted by 800XCR
I am rebuilding my 500's as well. How do you get 9.5:1 using flat top pistons and stock Merc (GM) heads? Thanks
you cant unless you reduce the combustion chamber to 100cc. I wrote that incorectly (sorry) I was thinking of some 604's that i am Dyno ing now . MY MISTAKE!!!! the 502's bored .030" had small dome JE's similar to the stock 502 pistons..
kevinr is offline
Old 11-23-2004 | 09:40 PM
performancemary's Avatar
Pressurized
I also took my 99 HP 500 Carb motors in for vale spring replacement at 270 hrs. After a leak down test we decided to refresh both motors. When we got it apart 8 of the valves on one motor were cracked and near ready to break apart. The springs on both were weak but none of them were broken. The cylinders, piston's and all the bearings looked great. Based on what I have read all the HP500 valve trains are on borrowed time after 300 hrs. Replace the springs at a min.
By the way mine ran fine before I took it in, no sign of a problem.
performancemary is offline
Old 11-24-2004 | 11:13 AM
Ran-Dom 32's Avatar
PM any performance gains noticed after refresh?
Ran-Dom 32 is offline
motobri
11-27-2006 11:02 AM
ActiveFun
1
07-07-2006 07:03 AM
Sonny Spectre 30
12-09-2005 07:40 PM
lilldeauce
Fountain
12
12-13-2004 08:01 PM
SLINGSHOT
11-30-2003 04:25 PM
