speed estimate >
speed estimate
speed estimate
Old 01-15-2005 | 09:59 PM
Registered User
Default Re: speed estimate
Originally Posted by Steve Zuckerman
I used to own a '98 24' H2X. I was able to GPS 80 with 625HP blown BBC. The boat had rocketship acelleration with a 28" Bravo. I tried a 30", lost acelleration and top end was about the same.
Have a friend who ran a blown BBC (same HP) in a H2X. He also put a Stellings set back box on his with +2" X dimension. The box really helped. He eventually managed 89 GPS,
also with a 28" Bravo.
Not that familiar with your model boat. The H2X has a lot more lift built into the hull than other Baja models. It has flat chines, 3 strakes per side, a small pad, and a 21o deadrise.
The most fun was rocking the world of a lot of twin engine guys that jumped on my little 24 "stock" Baja.
Regards,
Steve
EWB said that 89mph ride was a little un nerving at times..
DISTURBED1 is offline
Old 01-16-2005 | 08:54 AM
Plum_Crazy's Avatar
Originally Posted by blownbaja24
I would like some educated guesses on my top end. I have 1989 baja 24 sport,496 blown approx 600hp. What prop should I start with. I hoping to see close 80 mph.
It takes around 600 HP to propel my much smaller '88 Sunsport 196 to 80 MPH. I'm guessing you'll see around 75 MPH.
Plum_Crazy is offline
Old 01-16-2005 | 10:42 AM
Dave M's Avatar
Veteran: Navy
My .02 after reading this thread.... No ofense to anyone intended.
I would research other hulls that can easily run the speeds mentioned here with significantly less HP.
Dave M is offline
Old 01-16-2005 | 12:16 PM
Smitty's Avatar
My 24 Outlaw ran 75 on gps with 550 blown hp. I would start with a 28" Bravo 1. Baja has told me the "safe maximum" for that hull is 80 mph. If you modify the hook you may get more speed, but then you change the dynamics and it may cause a problem somewhere else.
If need to go over 80 I would also consider a different hull.
Smitty is offline
Old 01-16-2005 | 06:46 PM
thankyou for the advice,
I 'm going to take my chances with removing the hooks. Hope to see 75 plus. Talk to you soon with my next question.
blownbaja24 is offline
Longrange4u
5
05-15-2006 12:50 PM
HyperBaja
Baja
30
12-27-2002 01:43 PM
283CHECK
06-06-2002 12:56 PM
dreamer
06-03-2002 07:18 PM
merlin540
02-07-2002 11:55 PM
