Bravo- engaging while in neutral >
Old 02-09-2005 | 02:19 PM
Question Bravo- engaging while in neutral
Bravo/Quicksilver 3000 Series remote (1995)
Fine at idle but when I push shift lever release button and idle up in neutral (with lever forward) drive engages in forward.
If I push shift lever release button and idle up toward reverse- no problems.
I've cleaned and greased the detent ball (rear cap of drive) and adjusted shift cables
RickR is offline
Old 02-09-2005 | 02:26 PM
Ted G's Avatar
Default Re: Bravo- engaging while in neutral
I think those were recalled for that problem. It is very dangerous and you need to get rid of it ASAP
www.cbpba.com
Ted G is offline
Old 02-13-2005 | 04:23 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
You Need To Check Shifter Unit. ( Under Hatch) There Is A Plastic Set Gauge Too Set The Throw Disstance Correctley. It's Very Usefull When You Are Guessing At The Setting On The Shifting Unit.
WILDTHING TAZ is offline
hoozeyurdaddy
Drives and Lower Units
1
06-30-2007 09:10 AM
nevercanstop
1
02-21-2005 09:11 AM
Mad Hatter
15
07-07-2003 02:30 PM
Chart
4
07-01-2003 04:42 PM
