Marine Carb or Not >
Marine Carb or Not
Marine Carb or Not
Old 02-16-2005 | 03:21 PM
  #41
Default Re: Marine Carb or Not
The fuel curve, and metering circuitry needs to be set up differently for a carburetor with or without "J" Vent Tubes.
When I worked in the marine industry we had a boat catch on fire in the yard, and insurance would not cover it because some of the items on the engine were not USCG legal, even though that had nothing to do with the reason for fire.
For the slight difference in price, and performance why you you want to risk it?
RumRunner is offline
Old 02-16-2005 | 08:57 PM
  #42
mopower's Avatar
Toxic FORMULA
J tubes ...no J tubes The 330/454 415/502 356/454 all with Quadrajets don't have J tubes from Merc .
mopower is offline
Old 02-17-2005 | 06:43 AM
  #43
Originally Posted by SledgeHammer
Can anyone actually quote the exclusion in their policy that says there is no coverage if you use non USCG equipment? I have checked mine and there is no such exclusion. If anyone can quote the exclusion from their policy, name the company as well. I am not advocating using non USCG equipment, but I have seen these comments frequently about what insurance companies won't cover. If it is not specifically excluded, then it is covered.
As far as I know they don't have to mention that. Your automotive policy doesn't state that ANY & ALL replacement parts must be D.O.T. approved, but trust me if they are not they won't pay, and it's still against the law.
Old 02-17-2005 | 08:22 AM
  #44
I believe the vent tubs are cut at an angle so they will still pour down the carb throat.
Gary
Gary Anderson is offline
Old 02-17-2005 | 12:12 PM
  #45
Hang Time 27's Avatar
Whether or not your carb is marine spec will be a mute point when your boat catches fire from the engine compartment. Years ago my 750 holley melted and disapeared down into the intake manifold - Don't think an insurance adjuster would have been able to tell what kind of carb it was - cause it was gone! - Same with alumn valve covers and exhaust manifolds. -- fiberglass burns pretty damn hot.
Hang Time 27 is offline
Old 02-17-2005 | 12:13 PM
  #46
mopower's Avatar
Toxic FORMULA
Holley has angle cut vent tubes also . Lookin at those Quads. if the gas came out the vents , your guess is as good as mine which why the gas would go. depends which way the boat was rocking , I guess
The 350 Mags with the Webber carb that looks like the old Carter AFB is the same way too . So what make them ok
mopower is offline
alecsammy
4
10-31-2008 12:15 AM
Ran-Dom 32
Wanted
3
02-28-2008 10:29 AM
awesomerott
3
02-24-2005 08:04 AM
awesomerott
6
02-11-2005 10:26 AM
GeeterB
1
04-30-2003 01:54 PM
