Will a cherry picker (engine hoist) work for pulling an engine >
Old 02-13-2005 | 05:50 PM
Reed Jensen's Avatar
Default Re: Will a cherry picker (engine hoist) work for pulling an engine
I used a cherry picker to remove two engines from a 40 foot fountain on a myco trailer. I made an extension for the boom so that it would reach over the transom. The extension was about 4 feet long with a 30 degree angle in it to reach over the transom. I had to be careful not to extend it too far. But the height was over 11 feet at full lift.
Reed Jensen is offline
Old 02-13-2005 | 06:04 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Bet that was a sight being carefull not to get a little tipsy
US1 Fountain is offline
Old 02-13-2005 | 06:08 PM
what about just buying a chain fall from jc whitney for about $70.
find a good tree or a strong I beam to hang it from, or you can get real professional with a gantry crane.
BOATING ON A BUDGET is offline
Old 02-13-2005 | 06:14 PM
muffman's Avatar
Take the wheels off the trailer and put 4x4 blocks under the axles. ????
muffman is offline
Old 02-13-2005 | 06:20 PM
Oh yeah.... I used a fork lift to put them back in....
Old 02-13-2005 | 06:35 PM
I used a Harbor Freight 2 ton lift. It can lift 1000 lbs 117 inches in the air. I took a Big Block Chevy out of a Donzi 22 with one of these.
Engine Crane
IHTFP is offline
Old 02-13-2005 | 06:44 PM
JGB's Avatar
JGB
IHTFP, you did this with out screwing with the trailer etc? thx
Jim
JGB is offline
Old 02-13-2005 | 07:13 PM
Spectre5936's Avatar
I pulled the stock 330 from my 25' Larson Senza with a Harbor Freight motor hoist while it was on the trailer. Had to remove the oil pan/ pump after I got it off of the mounts before it would clear. Hopefully it will go back if I let most of the air out of the tires.
Spectre5936 is offline
Old 02-13-2005 | 07:19 PM
JGB's Avatar
JGB
what size harbor freight did you use? thanks Hope it goes back in for you.
Jim
JGB is offline
Old 02-13-2005 | 07:32 PM
JGB's Avatar
JGB
wish I could, though I'm lacking a tree... a good idea though. thx
JGB is offline
