Will a cherry picker (engine hoist) work for pulling an engine >
Old 02-13-2005 | 01:44 PM
JGB's Avatar
JGB
Question Will a cherry picker (engine hoist) work for pulling an engine
out of a cigarette 20 on a myco trailer? Does it go high enough to clear the deck? Has anyone used a cherry picker to do this?
The height I need to clear is 53 inches. The engine is a 350 chevy. The engine height is 32 inches. Thanks for any help or advice.
Jim
JGB is offline
Old 02-13-2005 | 02:12 PM
Sean H's Avatar
A to Z
Default Re: Will a cherry picker (engine hoist) work for pulling an engine
some do, some don't.. actually most don't....
you just need to make sure you have one that has at least 85" + hook and chain.... can you take it off the trailer? put it on bunks and lower it to the ground, that might be the easiest if you have the room to do that... makes working on it easier to at ground level......
Sean H is offline
Old 02-13-2005 | 02:15 PM
JGB's Avatar
JGB
thanks, unfortunately, I don't have that option. I saw one advertised on ebay that said it max lift is 8 1/2 feet. I would assume one like that would work? thanks again sean.
Jim
JGB is offline
Old 02-13-2005 | 02:18 PM
Sean H's Avatar
A to Z
Originally Posted by JGB
thanks, unfortunately, I don't have that option. I saw one advertised on ebay that said it max pole hieght is 8 1/2 feet. I would assume one like that would work? thanks again sean.
Jim
i would say if you can get at least 100"s you should be fine...
Sean H is offline
Old 02-13-2005 | 02:19 PM
JGB's Avatar
JGB
cool, thanks a ton.
JGB is offline
Old 02-13-2005 | 03:41 PM
bj502's Avatar
I swaqped a 454 with a 502 in a 208 Islander. I had to raise the tounge to lower the stern but I was able to do it.
bj502 is offline
Old 02-13-2005 | 04:03 PM
JGB's Avatar
JGB
BJ, thanks. Do you know what the hieght was that you needed to clear on the Islander(distance from floor to top-deck of boat)? thanks
JGB is offline
Old 02-13-2005 | 04:47 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Keep in mind that at max height, you might be lacking horizontal distance to be reach into the center of the engine compartment.
US1 Fountain is offline
Old 02-13-2005 | 05:03 PM
bj502's Avatar
Boats still in winter storage. Otherwise I could give you a dim. As above it was tight getting the engine to ballance. Letting air out of tires can gain some room too. I just did things real slow. Hope you figure things out.
bj502 is offline
Old 02-13-2005 | 05:26 PM
JGB's Avatar
JGB
I think It maybe easier to just hire a tow truck with a long or adjustable boom to pull it. thanks for your help and advice.
JGB is offline
