When do cats fly? >
When do cats fly?
When do cats fly?
Old 04-01-2005 | 04:59 PM
Elite Marine's Avatar
Default Re: When do cats fly?
TJ -
Providing you are in VFR weather, let her rip, even if it gets airborne, you're still rated and current aren't you?
Just kidding!!
Nice to see someone asking the right questions and doing the right thing by not just going out and becoming a statistic!!!
Take your time, have fun and be safe!!!
Elite Marine is offline
Old 04-01-2005 | 05:30 PM
Originally Posted by Airpacker
The higher you hang the trim, the looser the boat will run. As with anything in life, too much is always jut that....TOO MUCH. Conservative trim angles will keep the bow lower and help the boat take off, fly and more importantly land level. It will also reduce your chance of a blow over. You commented that you will know its coming long before it does.....probably not. Blow overs happen in an instant. Also important to your safety is learning the hulls cornering characteristics before finding out the hard way where and when it wants to spin out. Start easy and if you feel the outside sponson nosing in on a corner, ease up on the wheel, NEVER the sticks as this will amplify the problem and you will probably end up swimming. You will find that cats tend to "slide" thru corners at speed but dig and turn real hard at slower speeds.
As to your initial question, my daytona starts to "fly" at around 70 mph and really takes a set at 80.
Great advice. Do you have a tunnel tab on the boat? If so, use the same logic Airpacker has noted above: Conservative use!!!!!! Several cat owners NOT knowing or just simply forgeting to to bring the tab up have stuffed or barrel rolled their cat with improper use.
ROTAX454 is offline
Old 04-01-2005 | 05:55 PM
There is no tab on the boat. I just got 2 new Hyromotive Q-IV's at 29.5" which will be tried out Sunday. Cant wait. It's interesting what Matt & Julie at Throttle-Up did for me - They took props designed for a Bravo-1 and re-worked them for my 300 ProMax's. Reason - better transom lift. This should help my hole shot and allow me to get on plane faster and at a slower speed.
Thanks for all the insight - this forum has been a goldmine of knowledge and good advice.....TJ
tj309 is offline
activatorf1
Activator
5
08-22-2008 10:33 AM
Pure Energy
Superboat
5
09-22-2005 04:22 AM
Looney Tune
10-21-2002 06:12 AM
SHARKEY-IMAGES
09-23-2002 07:40 PM
