#6 Drive Fluid-wet sump >
Old 03-16-2005 | 12:57 PM
grand-illusion's Avatar
Default #6 Drive Fluid-wet sump
Just bought a boat with vintage 1995 wet sump #6's. What's every one running in these drives for fluid. I've ran Bravo's and XR's for years and have had great luck with Redline shock proof heavy. Is this stuff recommended for the #6's or is it best to stay with the Merc. I believe the previous owner ran Royal Purple.
grand-illusion is offline
Old 03-16-2005 | 01:27 PM
Default Re: #6 Drive Fluid-wet sump
If you order Merc fluid for a dry sump #6 it is just Torco synthetic. Mercury doesn't even repackage it.
check300 is offline
Old 03-16-2005 | 02:33 PM
cougarman's Avatar
grand-illusion,
What boat did ya end up buying?
Cougarman
cougarman is offline
Old 03-16-2005 | 08:07 PM
1995 50' Hustler w/trip 1000's out of northern IL. I see your's is back up...awful lot of hardware there for the price. Someone really needs to buy it. The unrigged 50 hull sold just before I called...this one ended up being a better deal anyway...at least I hope.
Old 03-17-2005 | 08:09 AM
clearcut3's Avatar
Got any pics?
clearcut3 is offline
Old 03-17-2005 | 02:47 PM
Brad Zastrow's Avatar
Run mercury hi-perf oil on wet sumps sixes.
Brad Zastrow is offline
Old 03-17-2005 | 07:38 PM
monstaaa's Avatar
we've used Mobil 1 synthetic gear lube and noticed a significant increase in free speed movement. in other words when you turned the prop shaft by hand it took less energy to turn. coincidently the boat picked up almost a full mph. may have been luck, either way the Mobil 1 is great stuff.
monstaaa is offline
masher44
Drives and Lower Units
4
07-27-2011 07:41 AM
horsplay
2
05-10-2007 09:17 AM
TeamPSI
6
02-01-2007 10:13 AM
JCPERF
02-22-2006 09:48 PM
TNTCustomMarine
01-11-2002 01:31 AM
