496HO Oil Temp Sender??? >
Old 03-31-2005 | 10:26 AM
Bill 3's Avatar
Default 496HO Oil Temp Sender???
I believe I need to find a better (proper) location for my oil temp senders. I have found them on the top of the block behind the intake manifold. It is in a "T" and both the oil pressure and temp are using the same port. My gauge temp starts at 140 and I rarely see the needle move, I know this is not right. I was hoping to find a place to tap near the remote oil filter, but no such luck. Any suggestions?
I am not the original owner and I can't believe this didn't bother anyone else. I just like things to work right.
Bill
Bill 3 is offline
Old 04-01-2005 | 07:35 AM
Bill 3's Avatar
Default Re: 496HO Oil Temp Sender???
I think I may have an idea on how to solve the problem. In looking at a breakdown of the block, it appears that there are 2 locations for an oil pressure sender. One on the top/back of the block and another just above the oil filter mount on the side of the block. So with my pressure sender on top, I am going to try and use the port just above the filter base. I think this should be fairly accurate also since hopefully it will be measured just before it exits to the filter.
Bill
Bill 3 is offline
Old 04-01-2005 | 09:28 AM
Had the same issue with my HO's. Sunsation sent me a kit that solves this problem. A spacer that fits between the oil filter and mount that has a boss for a probe. I think the part was made by innovation marine. I'll double check when I get home.
Quality Time is offline
Old 04-01-2005 | 09:34 AM
I got sick and tired of buzzers and alarms going off in my boat.
The solution is to disconnect all the wires you can find near any sender on the engine. I also snipped most of the wires behind the helm and that helped too. I have quiet, trouble-free boating now as most of my gauges don't work. I hated worrying all the time about temperature and pressure readings. Now I can concentrate on enjoying my time out on the water.
Please note today's date.
Edward R. Cozzi is offline
Old 04-04-2005 | 09:20 AM
Bill 3's Avatar
Quality Time,
If you don't mind, check and see who made your adaptor. I have searched for such a piece and haven't found anything. It seems that both ports have senders, I guess the computer uses a different sender from the gauge. I was just hoping for an easy fix.
Thanks,
Bill
Bill 3 is offline
22 DAYTONA
5
07-02-2008 03:20 PM
Dtile
7
02-18-2007 12:24 PM
CN24
2
01-16-2005 12:46 PM
Danny_Ocean
4
04-05-2004 10:47 PM
convincor
6
07-05-2003 06:09 PM
