Go Back  Offshoreonly.com > Owners Forum > Hustler
Where to put water pickups for whipples >
Old 07-03-2008 | 08:48 PM
Strip Poker 388's Avatar
Rob
Originally Posted by bbaur32
Rob what kind of plug are you running? Brand and what number. Whipples says one colder then stock (ngk 7). But mine seems to run better with the stock (ngk 6). Any input would help. Is your water pickup flush with the botom of the boat?
AC R42TS gap at 32,This is what Mark at Precision Marne recomended,It doesent load up,no signs of Det,never hurt one.Been changeing them around 30hr for the hell of it,
I Also ran NGK R5674-8 in my Scarab blower motor, Dustin also recomended this one to me when I first put the Whipple on.The AC's are cheaper also.
the 6 is pretty hot I run the 7's in my street car and when on the NOS the 8"s
Strip Poker 388 is offline
Old 07-03-2008 | 09:47 PM
Rob
exh temps
Old 07-07-2008 | 10:49 AM
Rob Thanks for the pics and the dyno sheet. I going to try out the pickup tube like yours. Is your mounted flush with the bottom of the boat or up or down a little. In the pics it look flush. Thanks for all your help!
bbaur32 is offline
Old 07-07-2008 | 06:05 PM
Rob
The front lip is flush,so the water rolls of the transom edge and goes up into the pick up,I would mount to a little lower to grab more water, I am going to roll the edge of mine to see it it will get more water,not that there is a prob ,it just looks like it needs more water coming out the side.I need to make a fitting on the inlet side to mesure the pressure, i have some used spare 12's I might drill and get a gage reading from,just havent gotten around to it, 4 season on the Whipples
I can take a closer pick
Old 07-08-2008 | 12:31 AM
Rob
new hustler
Old 07-11-2008 | 05:00 PM
Rob
388 with modified bottom
I think LMarth has a pickup shaped like these,
Old 07-11-2008 | 05:24 PM
Rob
Attached Thumbnails Where to put water pickups for whipples-drives-7-09-2008-011-large-.jpg   Where to put water pickups for whipples-drives-7-09-2008-017-large-.jpg
Old 07-11-2008 | 05:34 PM
Rob
Rob or anybody installed water pickups on 388 hustler for whipple intercooler? Can I install them on the upper step on back of the boat or do I have to put them down on the lower step by the drain plug?
some more info ,you can see my speedo tube where it is ,at a 100 the speedo quits
Prater
7
09-09-2008 06:03 PM
BobbyB
2
09-02-2008 11:51 PM
teddy38
26
03-13-2007 09:22 PM
bshzba
0
11-21-2006 08:29 PM
Leathl_WS6
Sutphen
0
07-11-2006 07:07 AM
