Go Back  Offshoreonly.com > Owners Forum > LaveyCraft
Interior Picts >
Interior Picts
Interior Picts
Old 01-01-2010 | 04:11 PM
  #31
When you say most guys cheap out on the blowers what do you mean by that?
twistedvelocity is offline
Old 01-01-2010 | 04:13 PM
  #32
Originally Posted by twistedvelocity
Do run sea strainers? this was something else I was thinking about.
Chroming usually weakens the part too
Of Course -You have no choice if you are at all serious and run in the ocean.
Pick one with.
1. the ability to get in and dump without tools.
2. the ability to backflush with a screw in hose connection.
UD
Uncle Dave is offline
Old 01-01-2010 | 04:14 PM
  #33
I mean they cut corners on the parts and machining they need because they listen to the wrong people.
UD
Old 01-01-2010 | 04:21 PM
  #34
I like the idea of dumping the strainer without tools.
I was thinking of building a little box in my engine compartment to hold a few tools belts and some oil.
I was thinking if I went the blower route that I would do a 383.
But I think if I built a good 427 sb I would probably get to as fast as i would want.
Are blowers really bad on fuel?
Old 01-01-2010 | 04:23 PM
  #35
I forgot does the strainer go before the seapump?
Old 01-01-2010 | 04:34 PM
  #36
Usually it does.
This stops the kelp, moss, grass, from choking the sea pump, and keeps this trash out of your coolers.....
Ive seen poeple do ALL KINDS of weird stuff though......
UD
Old 01-01-2010 | 04:47 PM
  #37
500HP of energy takes x amount of fuel no matter how you deliver it.
Blowers have some parasitic loss for sure.
Whipples are really good as far as adiabatic efficiency compared to roots type blowers.
UD
Old 01-01-2010 | 04:54 PM
  #38
IS there much point in having the power steering fuild cooler?
Old 01-01-2010 | 04:56 PM
  #39
Depends of how hard you are pushing against xHP of water flow and how often. Oil when pushed around- gets hot.
If you go external, steering this is usually taken care of.
UD
Old 01-01-2010 | 05:13 PM
  #40
Would an add on external kit be good that taps into the stock steering?
