Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Hatch Hardware >
Hatch Hardware
Hatch Hardware
Old 09-19-2007 | 10:52 AM
Default Hatch Hardware
Anyone out there have the hardware for a TRS sport engine hatch?
Looking for the two rear hinges and the front latches.
I know some of you are restoring / modifying some right now and if you happend to have that hardware available that would be great!
Kevin
Cigret1 is offline
Old 09-19-2007 | 01:37 PM
mr vinyl's Avatar
I will check,however the rear hinges are standard,the lock make be difficult...does it look like the one I have attached ?Bud
mr vinyl is offline
Old 09-19-2007 | 05:22 PM
Thanks! My hatch is raised a bit in the rear.
The center ring piece I see on your picture looks correct.
Cigret1 is offline
Old 09-19-2007 | 08:44 PM
mr vinyl's Avatar
Default Correct hatch Hinge
Both Perko and Attwood make a hinge that is close. I will check it out when I am at the shop. Bud
mr vinyl is offline
Old 09-20-2007 | 06:19 PM
mr vinyl's Avatar
Default Found Hardware
Thriller Perko still makes the Rear Hatch Lifting Handel...# is )776 Flush Lifting Handel 3-3/4 X 2-3/4. should be available from West Marine special order,cost $45.00...hinges should not be a problem. Glad we could help,call me on wrapping your Mag. Bud
mr vinyl is offline
Old 09-20-2007 | 06:37 PM
Perfect thanks for the help that takes care of the handle... Rear hinges are no problem, now I need the two latching mechanisms.... the push down and turn on each side of the hatch...
Thanks again!!!
Cigret1 is offline
Old 09-20-2007 | 06:54 PM
beakman's Avatar
Hey Cigret1!!! Why dont you get some scuba gear and go fish yours out!....hahahahahaha
beakman is offline
Old 09-20-2007 | 08:19 PM
24degrees's Avatar
Thanks again!!!
Maybe the boys over at donzi.net know.......?......might be the same stuff?
24degrees is offline
Old 09-20-2007 | 09:30 PM
mr vinyl's Avatar
Default Rear Latches
I have a set of rear latches,they will have to be re-chromed...there is someone looking at the Maltese Hull,if he buys it I will check if needs them. He indicated he was not going to retro the 74.
Also some one was looking for a hull ...I might have one available if the person who I promised this one to first does not take it. Give me a call...312-607-3115
mr vinyl is offline
Old 09-21-2007 | 08:11 AM
Awesome! I'll take them, Can you shoot me a message to my email so we can get each others contact info... [email protected]
Thanks for all the help
Cigret1 is offline
kracer
Cigarette
3
03-31-2008 02:08 PM
O.C.Barry
Cigarette
1
03-11-2005 11:06 AM
SHARKEY-IMAGES
General Racing Discussion
0
10-03-2004 06:39 AM
Shooter
4
08-19-2003 06:33 PM
