Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Restoration Progress 74 Maltese >
Old 06-13-2013 | 08:14 AM
  #91
mr vinyl's Avatar
Plan on being there.Bud
mr vinyl is offline
Old 06-17-2013 | 10:40 AM
  #92
Wish mine was that close to being done!
TMITCHELL is offline
Old 08-03-2013 | 08:36 AM
  #93
Default Help! Parallel Switch
Hey guys,
Need a little help wiring up the parallel switch on the dash and the solenoid between my battery banks/selector. Does anyone still have this setup?
What i have is 74 Maltese with 2 banks of 2 batteries (4 in total). Each 2 bank has the 1 - 2, Both, Off selector. In addition on the dash panel is a parallel switch that allows you to temporarily parallel the banks for starting purposes. It originally ran to a solenoid (4-wire) between the battery banks. It is no longer wired.
Does anyone still have this setup and how is it wired in? Photos, advice, etc. greatly appreciated.
Thanks in advance[ATTACH=CONFIG]505466[/ATTACH],
Jeff
Attached Thumbnails Restoration Progress 74 Maltese-boat-resto-5-9-13-005.jpg
JPrusinows is offline
Old 08-03-2013 | 09:13 AM
  #94
h2oboater's Avatar
Jeff here is the wire diagram set up for the switch.
h2oboater is offline
Old 08-04-2013 | 02:20 AM
  #95
I love to be in solidarity with all those who live in this Magnum [ATTACH=CONFIG]505493[/ATTACH][ATTACH=CONFIG]505494[/ATTACH]world
Attached last photos of my restored 81 Starfire thanks OSO the way i met Mr Vinyl
Giovanni
Attached Thumbnails Restoration Progress 74 Maltese-image.jpg   Restoration Progress 74 Maltese-image.jpg
giocariello@gmai is offline
Old 08-04-2013 | 02:24 AM
  #96
Attached last photos of my restored 81 Starfire thanks OSO[ATTACH=CONFIG]505495[/ATTACH][ATTACH=CONFIG]505496[/ATTACH] the way i met Mr Vinyl
Giovanni
Two more
Old 08-04-2013 | 01:47 PM
  #97
mr vinyl's Avatar
You did a beautiful job, all Bob and I did is find the Starfire and do the primary repairs to her.I see you lowered the floor for driver and passenger, how are you draining water that collects there? Also have you finished up the front cabin, pictures would be great.Bud
mr vinyl is offline
Old 08-04-2013 | 06:34 PM
  #98
Giovanni,
That is bad to the bone!! "Maledetto bella"
You are right Magnum owners and enthusiasts are the best. Here are the latest from our restoration. 99% complete.
Jeff and Dennis
Attached Thumbnails Restoration Progress 74 Maltese-boat-resto-7-24-13-004.jpg   Restoration Progress 74 Maltese-boat-resto-7-24-13-048.jpg   Restoration Progress 74 Maltese-boat-resto-7-24-13-035.jpg
Restoration Progress 74 Maltese-boat-resto-7-24-13-026.jpg   Restoration Progress 74 Maltese-boat-resto-7-24-13-028.jpg   Restoration Progress 74 Maltese-boat-resto-7-24-13-008.jpg
Restoration Progress 74 Maltese-boat-resto-7-24-13-031.jpg   Restoration Progress 74 Maltese-boat-resto-7-24-13-034.jpg
Old 08-04-2013 | 06:41 PM
  #99
Mark,
As usual, thanks again for your informative and quick response. Using the wiring diagram you posted, the manufacturers, diagram, and my 35 years with this boat, attached is what I came up with as a wiring solution. Can you take a look at it and see if yo recall this to be correct?
Green wire is to parallel switch.
Black is to ground
both 16 gauge and on liitle posts of solenoid.
Two red wires are two the "both" position on the battery selectors and then to the large posts on the solenoid.
these are 10 gauge.
It seems to be working and most importantly so does everything else that was working before! LOL
I can hear it clicking and both side still turn over. Hard to tell if it is boosting cranking amps as all batteries are fully chatged.
What do you think?
Thanks again,
Jeff
Attached Thumbnails Restoration Progress 74 Maltese-img00283-20130804-1553.jpg
Old 08-04-2013 | 10:37 PM
  #100
24degrees's Avatar
Jeff...you make me want to tear my Sport apart and restore to that level...so correct!
24degrees is offline
