Go Back  Offshoreonly.com > Owners Forum > Nordic
let it breathe >
let it breathe
let it breathe
Old 03-20-2006 | 09:38 AM
  #31
offshoreaj's Avatar
Default Re: let it breathe
Steve,
Thanks for the tips! I'm very familiar with this hatch strip; my Heat is 2000, & to clear Whipple pulley I had to move the rear bench forward ~3/4in, then to make up gap between hatch & bench I fabbed a spacer strip out of 3/4in plywood (covered in white vinyl), using original as template. You're right, working with that strip is a pain! I've been thinking for a long time that the Whipple sure might like some more fresh air, & after seeing the vents in yours I'm almost certainly going ahead with it. Thanks again.
Jeff
offshoreaj is offline
Old 03-28-2006 | 01:06 AM
  #32
sandman
Damn steve, that really is a sweet boat. especially after what I saw under the hatch. I just may have to make a special run up there when I get back and drive back home with my brother. You're talking about engines so I'm a bit more in my comfort zone.
I was actually considering fabricating a cold air induction system for mine. cold , dense air makes more power, period. No matter how you go about doing it (scoops, vents with ducts......) The trick is not allowing your engine to breath that hot compartment air. Kawasaki (the aircraft division) developed the best system for thier superbikes which actually pressurizes the incoming air as speeds increase (a poor mans blower) Obviously you have that problem licked with that SC. I have normally aspirated 1050 holley dominators to feed and want to make sure they get the good stuff. I just have to develope a trap of some sort to prevent the twins from inhaling a bunch of water if things get too ruff.
I do have another question for you and will post it in prop talk....Casey
sandcraft is offline
Old 03-28-2006 | 09:25 AM
  #33
Steve Zuckerman's Avatar
Originally Posted by MIKEHTMSR24
My buddy had a 95 32 w/ 525SCs and it would pick up 150+ rpm when hatch was cracked
Casey,
See Mike's comments here about your boat. He has a friend who had the same boat and evidently it needs engine compartment venting/induction as you estimated.
I was looking at Andy's, now the Hart's Heat this past weekend. I was surprised to see that the '99 and older Heats don't even have the transom/sunlounge intakes. The only way air could get to this motor was the bilge blower intake, which is about 3" in diameter. Not too efficient.
My friend Eric/EB Marine showed me a Mercury manufacturer/
dealer bulleting regarding overly enclosed/restrictive engine compartments causing poor performance and hard hot starting. So Mercury does agree that this is an issue. They say they have measured engine compartment temps from 176o to 200o. That can't be good for performance. I'll try to get him to email it to me so I can post here.
Regards,
Steve
Steve Zuckerman is offline
Old 03-28-2006 | 02:45 PM
  #34
Steve,
Are the Harts going to add some vents in the rear seat? The older Nordics have zero airflow. That is pretty lame for a company the is located in the desert.
Magic Medicine is offline
Old 03-28-2006 | 04:56 PM
  #35
Originally Posted by Magic Medicine
Steve,
Andy,
Yes, I gave Vence a billet vent like the ones I have and he is going to install it soon. I originally was going to install 3 of them across the hatch. I realized after starting the project that there is a rib in the center of the hatch that I didn't want to cut through, and that 2 was a big improvement over stock.
Steve
Old 03-28-2006 | 05:01 PM
  #36
Originally Posted by Steve Zuckerman
Andy,
Steve
Steve,
I am glad that Vence is installing a vent that should help keep the engine compartment cooler.
Old 03-29-2006 | 11:44 PM
  #37
sandman
Hey Mike, I was wondering if your friend has any pics of the cabin area of that 95 nordic. I have a 93 32' and after some research found it was built as a para sail boat. (the platform was never installed) As this was built as a work boat, none of the amenities were installed so I have a lot of work to do in making it a plush, liveable boat like the new Nordics. Thanks....Casey
Old 09-27-2006 | 06:50 PM
  #38
TTT,
Rage, here's an extensive thread on air intakes. This applies to Heats and Flames. The deck and hatch on the Rage is similar, so maybe this will work for you.
Regards,
Steve
Old 09-27-2006 | 09:39 PM
  #39
MIKEHTMSR24's Avatar
Sorry Casey I didn't take any pictures back in those days. My buddy went through a divorce and he is....... I don't know where he is or what state.
MIKEHTMSR24 is offline
Old 09-27-2006 | 10:10 PM
  #40
Rage's Avatar
Linster,
I saw a Velocity VR1 that had very slick ductwork. It had 4 or 5" PVC pipe glassed into both deck side air intakes, that led directly to the flame arrestor intake of the 500EFI. May be one of the boats you are talking about. Gotta admire the ingenuity.
Steve
Steve,
Where on this boat were the air inlets located? Would this work on a Rage do you think. This is along the lines I am interested in.
Bill
Rage is offline
