Go Back  Offshoreonly.com > Owners Forum > Nordic
let it breathe >
let it breathe
let it breathe
Old 11-07-2006 | 06:32 PM
  #51
Steve Zuckerman's Avatar
Default Re: let it breathe
Rage,
I used a black sharpie to outline the cut. A 1 1/2" hole saw to give me nice radiused ends, and then I did a plunge cut with a circular saw to do the straight sections, and that worked well. I have a roto zip and did use it to install 3 pop up cleats (1 on the nose, 2 on the side decks). You would have to have a steadier hand than mine to use the roto zip to make those long straight cuts. Maybe if you installed a temporary guide, like a small 1/2" X 1/2" X 18" board, screwed to the hatch.
You may want to reread my specific instructions earlier in this thread.
Regards,
Steve
Steve Zuckerman is offline
Old 03-08-2007 | 11:19 AM
  #52
Steve,
Where did you get the purple vents?? Those are great and I would like to add them. My boat is all stock but.... The subwoofer is in the engine department!!
Brad
stoutman450f is offline
Old 03-08-2007 | 06:55 PM
  #53
Originally Posted by stoutman450f
Steve,
Brad
Brad,
They are Eddie Marine thin line billet vents.
www.eddiemarine.com
Regards,
Steve
Old 03-21-2007 | 11:59 AM
  #54
Hey Steve,
I was looking at this again. Do you have two of the Eddie Marine 2.5 x 17 large vents ? I can't tell from the photo if you have one on each side.
Thanks - Brad
Old 03-21-2007 | 12:33 PM
  #55
Hey Steve,
Thanks - Brad
Brad,
That sounds correct. I'll measure them today. Eddie Marine should have my ordering records. You can get the part #s from them if you need to.
Regards,
Steve
Old 06-19-2007 | 10:21 AM
  #56
Rage's Avatar
Steve,
Anything new on getting cool air to the engine intake in a Nordic? In my case a Rage. I have finished the engine work and back to the air intake improvement issue.
Rage is offline
Old 06-19-2007 | 10:42 AM
  #57
Originally Posted by Rage
Steve,
I haven't seen a Rage in a while, but I think the engine hatch is similar if not the same as the Heat's. So, the hatch vents should work on your boat as well.
Mine is still working fine. Other alternatives are an engine hatch scoop (not practical on a "lake/non-race boat") or Monstaa's deck side induction vents, which I like a lot. I think the advantage his sytem has over my setup is there's probably a better ram effect on the side decks, and you wouldn't get as much engine noise in the cockpit. Personally I don't mind the noise, but I have friends who cover their ears due to the blower whine on my boat at speed.
If you're coming to the Jamboree this weekend, I'll show you my setup.
Regards,
Steve
Old 06-19-2007 | 10:56 AM
  #58
Rage's Avatar
Yes, the engine noise will be an issue for me so I am only considering intake designs that would come from the gunnels or below the rear bench seat. I plan on doing some testing of air pressure differential between the engine intake with the hatch closed versus various potential air intake access points with a jurry rigged manometer. Are you aware of anyone having done this kind of testing before and if yes what were the findings?
No we will not be at the Jamboree. I would like to see your set up first hand.
Rage is offline
Old 06-20-2007 | 03:08 PM
  #59
I have never done any manometer testing........anyone else?
Steve
Old 06-20-2007 | 03:22 PM
  #60
Talking
Steve
Is that where you squeeze their boobies and guess their age?
kennyo is offline
