Go Back  Offshoreonly.com > Owners Forum > Nordic
anybody need a 27" P5-X >
Old 05-17-2007 | 10:54 AM
The 25 P5X will turn about 50-100 RPM less than a 26 Bravo 1 prop. I ran those 2 props on my 28 Heat when it had a naturally aspirated 540. I could spin them to 5600 RPM around 75 MPH. The P5X ran great and really reduced prop slip. This was before I added a drive spacer.
bobl is offline
Old 05-17-2007 | 10:58 AM
Originally Posted by boatingbent
I have a 2005 Heat and i am turning a stock 26P 4 Blade B1 Prop...My RPM`s are around the 4950 mark....I am in the market for a new prop.....Sounds like some of you guys know your props.....Whatcha think I should go with???
BTW my Heat came with the 496 HO ...After 1st season I had bob at FTM do the Raylar install on mine....I also have the 1 inch spacer in mine.........I have one time under perfect condition GPS`s mine at 75.9 MPH......
Bent, your peak HP is at 5200 RPM. However, you are only down about 10 HP at 4950. I think labbing the 26 and then adding a slight amount of cup would do the trick. You must have the cup or you'll lose a lot of speed.
bobl is offline
Old 05-17-2007 | 05:45 PM
Steve,
I will have to verify the x-dimension. The only checking I have done is to measure from the bottom of the transom up to the outdrive. Mine is around 1 to 1 1/2 inches lower than the other 2 Heats in the area.
The power tech 5 blade looks similar to a B1 with the exception of more cup on the end of the blades. I have attached a picture of one. Since there is minimal slip, the power tech 5 blade is really sluggish out of the hole.
I plan to make it to the Jamboree.
Bill
File Type: doc
boaterh is offline
Old 05-17-2007 | 07:36 PM
I have a labbed 26 p5x on my 28 heat with a 500 efi. 1" spacer it runs 73.4 at 5100 to 5150. I will never go back to a 4 blade.
johnlomant is offline
Old 05-17-2007 | 08:13 PM
Steve Zuckerman's Avatar
Originally Posted by boaterh
Steve,
Bill
Bill,
That looks like a 5 blade Bravo one, not bad. It is definitely a bow lifter type prop.
I would have it blueprinted to your boat, and I am sure you'll be happy with it. Nice find.
Regards,
Steve
Steve Zuckerman is offline
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
Ben@SRP
14
10-13-2006 09:11 AM
mikesufka
12-26-2002 11:23 AM
