Go Back  Offshoreonly.com > Owners Forum > Nordic
Prop for Heat >
Prop for Heat
Prop for Heat
Old 05-31-2012 | 09:11 AM
Default Prop for Heat
Has anyone tried a Mirage 3 blade prop on a Heat with the 496HO ?
MMCHARGER is offline
Old 05-31-2012 | 12:21 PM
I would stick with the Bravo1 setup that the heats come with. The 3 blade I dont think would have enough bite to her, esp with the high X dimension Heats rock from the factory.
Jay Gadsby is offline
Old 05-31-2012 | 12:32 PM
Indy's Avatar
Member #154
Ditto, and you might want to look into lowering the X to get better performance. There are a few here with good experience with that modification.
The best prop for my Heat was a blueprinted and slightly sharpened 24B1. The 26 was too tall and none of the labbing I had done to the 24 or 26 mattered.
Indy is offline
Old 05-31-2012 | 05:47 PM
Has anyone tried a revolution 4 on a heat? The biggest they make is a 25 pitch so that counts it out for people with more horesepower. It seemed to work well on my rage.
oboyskibum is offline
Old 06-01-2012 | 09:33 AM
I have seen quite a few people run the Hydromotive setups on their Heats, I would check into them. The price isnt too outrageous, and the guys I have seen with them have quite a bit o power pushing them as well.
