Weekend Plans
Old 06-22-2011 | 12:56 PM
  #271
SS930's Avatar
Because he already has these... But yes, this would be quick and easy (and the same size Mike):
http://www.jegs.com/i/Moroso/710/85466/10002/-1
These are the ones I use on my cars:
http://www.jegs.com/i/Moroso/710/85500/10002/-1
SS930 is offline
Old 06-22-2011 | 01:12 PM
  #272
SS930's Avatar
Originally Posted by madhatter42
I've never liked the idea of octane booster. Just my humble opinion, I'd rather use av gas, or mix it true than trust it.
Pat,
MMT works to boost octane, it's a fact. The down side is manganese will azz up cats and O2 sensors, but this isn't an issue with boats (although the EPA probably wouldn't like it being used on the water).
The use of aromatics to raise octane is expensive and takes a lot more volume (10%-20%) to do the same thing. MMT isn't an aromatic, but it's an effective octane booster if you're simply looking for a little extra protection while breaking in your engines... plus it's easy to carry and add.
SS930 is offline
  #273
Sick Stinger's Avatar
Brotherhood #1
I didnt see the larger ones. I only say the smaller ones. But even so I can get the brackets for 30 each and just make a head mount bracket and I should be good to go.
Hey are we taking the Viper to check out the Jeep?
-Mike
Sick Stinger is offline
Old 06-22-2011 | 01:14 PM
  #274
SS930's Avatar
-Mike
If the weather is nice, we could do that.
BTW, why do you need/want another Jeep??????????
SS930 is offline
Old 06-22-2011 | 01:31 PM
  #275
Brotherhood #1
I dont have one Marissa does. I Have the Dodge, Vette, Nova, and Toyota. Sold the Vegimite
-Mike
Old 06-22-2011 | 03:12 PM
  #276
You can raise octane with toluene too.
30ctsutphen is offline
Old 06-23-2011 | 06:12 AM
  #277
............or vodka.
kreed is offline
Old 06-23-2011 | 06:30 AM
  #278
SS930's Avatar
Vodka will lower octane as most is only 40% ethanol, but straight grain alcohol will raise it! Keep in mind the stoichiometric ratio of ethyl ethanol is completely different than that of pump gas, so you might need to fatten your mixture if you plan on ruining significant portions of grain... But that might be considered alcohol abuse!
SS930 is offline
Old 06-23-2011 | 06:32 AM
  #279
SS930's Avatar
BTW, the weekend weather is starting to look better.
SS930 is offline
Old 06-23-2011 | 08:10 AM
  #280
Brotherhood #1
F'N rite it is.
-Mike
