Long Island NY Info
#42
Not sure I agree with your first statement. my boat motors are quite literally car motors straight out of a chevy. No matter the motor, the principle of matching piston stroke time to a fuel burn rate still holds true.
#43
from a reliable source:
Octane rating or octane number is a standard measure of the anti-knock properties (i.e. the performance) of a motor or aviation fuel. The higher the octane number, the more compression the fuel can withstand before detonating. In broad terms, fuels with a higher octane rating are used in high-compression engines that generally have higher performance.
Not sure how my post was wrong...please explain Adam.
#44
Your math is correct but the key point your leaving out is cylinder head temps......driving around on the streets and not beating the crap out of it, you can run a NASCAR engine on pump gas.
#46
Answer this question: Why can you higher compression on the same octane by switching from iron to aluminum heads??? Jeff, feel free to answer because I think you prolly know...
#47
Can we move on now? I dont think the OP really wanted to have this ongoing conversation...
#48
Basically I choose to run 93 when available because it is a safer play.
I guess up here I will just drive a little more conservatively and use regular and change the tune up a little.
