Go Back  Offshoreonly.com > Race Talk > OPA/The Jersey Boyz
To Dyno or Not to Dyno. Thats the question >
Old 11-23-2011 | 07:21 AM
Originally Posted by FandRRacing
I must be dumb. How does this work? Do we factor in a handicap based on power to weight?
More HP = More weight in boat.
sbracing is offline
Old 11-23-2011 | 07:24 AM
Originally Posted by Wazzup Racing
Considering a mockup race to see if it works
Boat is ready. Any ice on the Barnegat yet?? When & Where.
sbracing is offline
Old 11-23-2011 | 07:59 AM
TeamSaris's Avatar
Driver-441
Racer
Now how does the boat itself get factored into this? X-Dimension, deadrise, pads, steps..that can make a low horsepower boat spank a big hp one.
Id love to do something like this, real racing!
TeamSaris is offline
Old 11-23-2011 | 08:48 AM
2 Trick Rick's Avatar
Racer
Maybe grab 5 or 6 boats for a test race at the first round after everyone has competed in there "p" classes.
Gary and I are in.
2 Trick Rick is offline
Old 11-23-2011 | 09:19 AM
Originally Posted by F1-00 Racing
For 2012: Take care of the SCL and the SVL. Leave the Brackets alone. Perfect a small amount of boats b4 you bring it to the masses
2013: Start phasing in the Brackets
If all class 6 agrees, then I see no reason to wait. We have at least 7 boats that raced in 2010, it would be a perfect test class.
sbracing is offline
Old 11-23-2011 | 12:11 PM
Pwrbt33's Avatar
Come on Rich, build your new engine first!!!! Then we'll test this new system.
Pwrbt33 is offline
Old 11-23-2011 | 06:08 PM
Wahoo ATV's Avatar
Racer
It is acceleration that kills a class not top speed. HP/Weight isn't perfect, hard to dial in and the weight can be an advantage Thinking aloud, what if you set a fixed time from 30-70mph. Everyone could build whatever they want to meet that time. Tech could be test boat, record weight and gear ratio, seal engine and stamp the prop.
Weigh all boats as they come out and hold the top three in the water for 30 minutes for protests.
Wahoo ATV is offline
Old 11-24-2011 | 10:03 AM
Michigan Mad Man
I think out of every Class 6 boat there is only one that has a stock motor all the rest have racing engines. Put them in Class 6 by themselves and we will run Class 6 Modified or I will make them a great deal on our spare motor or they can have the one right out of the boat. If I have to add weight for the horsepower I will have to buy a new truck with a higher GVW to haul my boat !!!!!!!!!!
TylerCrockett is offline
Old 11-24-2011 | 02:41 PM
TYPHOON's Avatar
In my opinion only. For class 5 and 6 use the dyno only as a way to limmit the HP in those classes. Example would be class 6 has a 500 hp max and class 5 has a 650 HP limmit. And reasanable matching tourque numbers. No one adds any more weight yet. Take baby steps in these classes. Still GPS racing
SVL and Cat light keep as a spec style class and use the dyno as a way to tec the boats before and after the race.
MD
TYPHOON is offline
Old 11-24-2011 | 04:55 PM
can you run a small block in class 6 that is 500hp n.a.
innerrage is offline
