28 single x-question >
Old 08-31-2005 | 11:43 AM
littledcsrodshop's Avatar
Question 28 single x-question
Hey guys, I am trying to find out what my x dimension is on my 28 single, and also what it needs to be. It has a stern powr drive so referance points on the drive will not help much. What is the best way ( or the standard ) to measure
this ? I do know that this drive has a 21.8" shaft to shaft dimension. How far does the prop shaft need to be below the bottom of the v on the hull ? The boat does not have a notched transom. Thanks in advance for the help, Scott
littledcsrodshop is offline
Old 08-31-2005 | 02:56 PM
BRUCE SEROFF's Avatar
Default Re: 28 single x-question
from my experience, the prop shaft should be between 4 and 4 3/4 inches below the bottom
BRUCE SEROFF is offline
Old 08-31-2005 | 03:01 PM
Thanks Bruce, Is that with a notched or regular transom ?
Old 08-31-2005 | 03:02 PM
regular transom...no notch
Old 08-31-2005 | 03:08 PM
What kind of prop slip are you seeing with that setup ?
& with what props ?
Old 08-31-2005 | 03:37 PM
i run a 26 B-1@5800 we're seeing around 16-18% slip
Old 09-07-2005 | 01:11 AM
I'm agree with Bruce on the #'s he posted. I have a nothched transom and am in the 4.25-4.5" area with slip #'s in the same range. I was 1" higher before and couldn't carry the bow enough and slip was higher.
Griff is offline
Fast Shafts
Magnum Marine
8
10-09-2007 08:07 PM
SeaWeasel
06-13-2006 11:24 AM
damdonzi
Pantera
6
08-25-2005 07:34 AM
damdonzi
Pantera
3
08-31-2004 08:46 PM
Scarab28
7
06-11-2004 05:49 AM
