Gen 2`s out Gen 3 in
#74
Registered User
The sleeker scoop looks much better, but I've always had a thing with the drilled holes in the rear of scoops. They look like a cheesy afterthought. A pair of two or even one longer billlet grillle would look much nicer, even if they were just painted white. It is the view you'll hope everyone sees anyway.....Just my .02 cents worth....
#75
Registered User
Here is the finish work, cranked it up today and went out to test the Gen 3`s. All I can say, is that it is a bit louder and at top end it lights it up!!! here are some pics.....
#77
Registered User
Look at a perfedt 1/4 inch round clearance around the pipe and the 5 inch mouth. If I take some video of the motor running, who volunteers to load it in this section. I dont know how and I will send the video Fedex.
#78
I wish I could. I only have posted vid with a digital camara. I up loaded it to you tube or something and it was follow the directions. VHS to a computer???? I have a friend who might know.
I tell you what, take some vid of it running in the water and other stuff and I'll make it happen
#80
Where do you dump the cooling water, with the two fittings above the drive?
If so how far from the end of the tail pipe do you connect the hose, and how hot does the end of the pipe get?
Edit: I found the pics of the tail pipes...
