Speed of 24 w/ HP500? >
Old 04-02-2005 | 02:42 PM
  #51
Tim G.'s Avatar
Performance Boat Center
Default Re: Speed of 24 w/ HP500?
Storm-
You could probably get the flippers from the 280 tabs and bolt them up.... I think the transom mounts are the same..
A lot of guys change the flippers from 280s to 380s....
Albert may have some 280 flippers you may be able to get hold of....
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 04-02-2005 | 03:51 PM
  #52
Stormrider's Avatar
JC Performance Engines
Tim, thanks, but Jo says the short tabs will work better, as the boat not being as sensitive to them... I can always change if I feel differently.
Jo/Pepe, you can chime in on the slip issue anytime.
Stormrider is offline
Old 04-02-2005 | 04:34 PM
  #53
Jmemoli's Avatar
Goumada P5-38
River rat dude,
I was reading your post felt I would chime in ( for what its worth) .
The cam you are running is a bit aggressive. 240 @ .050 is a bit radical. Is it a roller , or flat tappet?? I think it will work fine however , if you get rid of the exhaust manifolds you have . That cam in a 10:1 454 should make over 500 hp in the 5600-5800 RPM range . With the high duration comes overlap, and overlap in a motor requires good exhaust to help scavenge.
Throw a set of CMI elbow tops on and I am sure you wont be able to hold on anymore .
Remember , hp isn't everything - Torque is king -When in doubt , less cam is better .
Good Luck !
Jmemoli is offline
Old 04-03-2005 | 06:42 PM
  #54
Elite Marine's Avatar
You make a good point with the exhaust.
I'm considering changing to headers from my Powerflow manifold. Might help the engine breath and pick up a few HP.
Elite Marine is offline
Old 04-04-2005 | 07:51 AM
  #55
Jmemoli's Avatar
Goumada P5-38
Pan 28,
I was running a set of Gils in my 540 , which had a cam in the 240/250 dur2 .050 range, with 114 LS .
When I changed over to the CMI elbow tops , I picked up 6 mph and 400 RPM . A night and day difference .
From my experience , cams with Intake less than 220 @ .050 and with little overlap ( 114 or higher) will work OK with stock exhaust . Little gains would come from CMI , or good flowing exhaust in these engines .
Jmemoli is offline
Old 04-04-2005 | 10:00 PM
  #56
I'm running a Crane HR-214/325
[email protected] [email protected]
.059/104 Degree Intake
.034/114 Degree Exhaust
Gross Lift .553 with 1.7 Ratio Rockers
The only difference between the Dyno and the boat was the exhaust. I have still had a difficult - next to impossible time getting up over 5,000 RPM in both my 24' and the 28'.
Sorry, didn't mean to hijack the thread!!!
Old 04-05-2005 | 07:46 AM
  #57
Stormrider's Avatar
Kirk, I'd call IMCO.
Old 04-05-2005 | 08:33 AM
  #58
Jmemoli's Avatar
Goumada P5-38
Kirk,
the cam you are running has 214 @ .050 , andlooks to be installed on a 104 Intake Centerline .
If so , I am sure it will not turn over 5000 RPM in the boat .
I doubt headers will do much here . I am sure this cam makes good torque . It is pretty mild . You said you put this motor on a dyno?
What did it make and where ? What exhaust was used on the dyno?
Jmemoli is offline
Old 04-05-2005 | 08:58 AM
  #59
IRONMAN's Avatar
How much boost do you see at 5000 Kirk? Is the carb at least an 1100 dominator?
IRONMAN is offline
Old 04-05-2005 | 05:34 PM
  #60
The cam has been installed at 110 Degree Intake Centerline.
It's fuel injected with larger injectors, cleaned and flowed. ECM reprogammed in the boat while running helped a little, but still not getting the same power as on the dyno.
Dyno Numbers:
RPM HP Torque
4000 542 711
4500 603 705
4800 625 684
5000 626 659
5300 642 635
Thanks for the help!!
