Speed of 24 w/ HP500? >
Old 04-11-2005 | 06:53 PM
  #61
Default Re: Speed of 24 w/ HP500?
Jmemoli,
you are right about that exhaust, I put a set of IMCO stainless steel 4" risers on top of the exhaust manifolds and just that made a huge difference. With the motor and boat how it is now I am getting 68 mph with 4 people and 50 gallons of gas in fresh water and about 72-73 mph in salt water with the same weight load.
riverrat772003 is offline
Old 05-16-2005 | 01:44 PM
  #62
Stormrider's Avatar
JC Performance Engines
My boat is finally ready. Going out for a run tonite to dial it in.
Got a labbed 26 B1 that should do the trick.
How I'm still sitting at my desk, I'll never know.
Stormrider is offline
Old 05-17-2005 | 01:30 AM
  #63
Titan's Avatar
Heard the boat ran well Storm. Any pics lets see them. Oh by the way the boat will be faster when JC gets out or loses weight. Which ever comes first!
Titan is offline
Old 05-17-2005 | 07:36 AM
  #64
Stormrider's Avatar
funny you mention that... the boat used to list to port, but when jeff drove, it listed to starboard.
Old 05-17-2005 | 09:24 AM
  #65
Titan's Avatar
Funny!!!!!!!!!
Titan is offline
Old 05-17-2005 | 09:26 AM
  #66
IRONMAN's Avatar
How did it run Storm? Did you get to compare the B1 with a stock mirage 23 or 25? I will be gettin mine wet next week but I am going the other way,from the labbed B1 to a stock M+. Good luck Chris
IRONMAN is offline
Old 05-17-2005 | 12:19 PM
  #67
Stormrider's Avatar
Ironman, it ran like crap.
I'd like to try a 24 and 26B1, but for now i think i'll throw back on my 23" Mirage+. That is what i ran last year and it will give me a good comparison.
With this so called "labbed" prop, it ran 71.5 at 5100.
What was funny is that we were running w/ a 21 superboat w/ merc 300.
He claimed he was running 6000rpm which = 80mph, from his gps last yr.
We were not close to 80.
Old 05-17-2005 | 02:52 PM
  #68
IRONMAN's Avatar
From the looks of your dyno sheet in the other forum I think your setup will like the 23 or 24" better. I have found it easier to make any fine carb or timing adjustments with lower pitched props then load it down after engine adjustments are made. Good Luck, Chris
IRONMAN is offline
Old 05-20-2005 | 07:25 AM
  #69
IRONMAN's Avatar
How is this for drive height? It is at 17.75"
Attached Thumbnails Speed of 24 w/ HP500?-2005_0515_155009aa11.jpg
IRONMAN is offline
Old 05-20-2005 | 07:57 AM
  #70
Stormrider's Avatar
sounds bout right.
I'm at either 17.5 or 17.25"
