Hmmmmm...so has anyone ever tried a shorty? Or will that just make it a btch to get on plane? The draft does seem a bit deep at 36 inches....same as almost all PQ's including their big cruiser!(provided their specs on their websight are correct)
Take a 6 or 8 foot straight-edge and in the section of the hull between the keel and the inner-most strake run the straight edge from the transom towards the bow of the boat. If you have any gap between the straight-edge and the bottom, you have a hook.
Read the 5th post in this thread by Brett at BBlades. Brett used to work for Mercury and knows his stuff. http://www.offshoreonly.com/forums/s...light=porpoise |
Originally Posted by pachanga
(Post 2373538)
http://www.offshoreonly.com/forums/s...d.php?t=151371 |
Originally Posted by Knot 4 Me
(Post 2374429)
Bottoms are probably simillar and therefore results might be too.
One of the guys on this forum swaped out his stock bravo drive for an Imco shorty on a 27 Laser. I don't recall the results. If you get a chance let me know what you see once you put a straight edge on the bottom. I'm really curious to see if theres a hook or not.
Originally Posted by Fast Forward
(Post 2375291)
Pq 260 Xl
I had my '98 26 PQ for almost 9 years and it was powered by a stock 502. Top speed was around the 65 mph mark. With the 23 degree deadrise and lighter weight I wouldn't want to go any faster unless you had some serious tabs in the back to control it. Mine would never porpouise at all under any condition. What it would do is start to bounce from chine to chine. Scary, you really had to have good throttle control. Knowing this I would find it tough to see that hull design at 80! Hope your plans work out and you achieve your goal, safely!
you should give chris mills at extreme body works a call. he has been talking to to the eds at powerboat on doing a before and after on blueprinting a hull. he just finished up a blue print on a older 25 predator. the hook your talking about probibly was not molded in, could have formed form your trailer or some other form of storage thats not supporting the transome good enuf. the shorty your talking about needs some sirious disscusions with imco. the low x on your boat is most likely for bow lift. you will most likely need an extension box for your boat to ride correct. hope this helps
I realize a 23 Nova and 26 PQ are two completely hulls but thought I'd throw this into the conversation as it may help. My Nova has the hook near the transom. Don't know if it's similar to the PQ hook as I've not had the opportunity to check a PQ hull out. Think I mentioned this in another PQ thread but, in relation to the chine walk, my Nova started chine walking in the low/mid 60's and would continue and get worse on up to +70 GPS. It would get scary bad, and I was not able to "drive through it". Throttle Up tweaked my 25 Mirage Plus and the walk was completely gone after that. I've had the Nova a tad over 73 on GPS with no walk at all. That said, it might be worth discussing prop work with Throttle Up or the prop shop of your choice.
So whats the verdict on the hull?? Does she have a hook??
| All times are GMT -5. The time now is 12:46 PM. |
