Go Back  Offshoreonly.com > Owners Forum > Powerquest
PQ General Discussion >
Old 08-02-2013 | 10:45 AM
  #3491
Originally Posted by verbi69
Probably was up to drain his bladder. You know how many times a night you old guys get up to visit the can.....
Don't remind me!!!!!
inknppr is offline
Old 08-02-2013 | 11:23 AM
  #3492
Originally Posted by Need4SpeedGTCS
Check it at WOT. You want the highest demands on the fuel system to see if the pump can keep up. Are you having an issue?
Awesome, good to know. I'm still down 500-600 rpm both engines. I'm thinking (hoping) its a fuel delivery issue.
I don't believe valve springs go bad over the winter. First year of owning the boat it would bang 5200 rpm very time the sticks got mashed, put it away for the winter sleep and first ride out down 500 rpm. Changed all fuel filters as well.
Last year I would run sea foam injector cleaner through it and it did slowly but gradually get better.
This year down on rpm big time. I have not done a compression or leak down on it. I will pull plugs and do the basics but its time to find my problem so that I dont hurt the motors, and also so that i can go and run with a certain PP!
verbi69 is offline
Old 08-02-2013 | 11:56 AM
  #3493
Here is a link to a triple 700, 48 ft Fountain with Arnesons.......
http://www.boatdealers.ca/usedboats/...-for-sale.aspx
verbi69 is offline
Old 08-02-2013 | 02:10 PM
  #3494
To build power you need good air, fuel, spark & compression. Checked your flame arresters, doubt they'd be an issue. Confirm fuel pressure. Ever put in a set of plugs. If all is good time to move to compression / mechanical concerns. Did the rpm loss happen after you had the props worked? Change to the pitch may be topping out the engines, only so much hp & torque.
Hope all turns out well and its nothing too serious...
Finally, headed to the lake tomorrow. Can't wait to run the Whipples!
Need4SpeedGTCS is offline
Old 08-02-2013 | 05:04 PM
  #3495
Originally Posted by POWERPLAY J
Possibly a ZR??? If so that is a very nice package!
Hey J, no not a ZR, although my buddy has a nice one with 600/SCXs and it's nice. I need something with a nicer cabin, I have a 3 year old daughter.
Pwraddr is offline
Old 08-02-2013 | 08:38 PM
  #3496
Need, my issues were right out of the box in the spring with no changes to anything. Both engines were down from the first ride out so that's why I'm skeptical it could be valve spring related.
verbi69 is offline
Old 08-02-2013 | 09:09 PM
  #3497
Not too late to trade mike
AJ POWERPLAY is offline
Old 08-03-2013 | 01:52 PM
  #3498
Lol!
verbi69 is offline
Old 08-16-2013 | 07:53 AM
  #3499
Hey Tommy!!!!
When you changed out the cams in the 496 to HO's, what was the cost involved? Did you get the computers reflashed or did you get new ones?
How many hours of work from start to finish??
Thanks,
Mike
verbi69 is offline
Old 08-16-2013 | 09:08 AM
  #3500
Hey Tommy!!!!
Thanks,
Mike
Oh oh...having a lift loss problem? Is that the concern you're having or are you just upgrading? Hope all turns out well.
