It's time to see your PowerQuest
#81
Wally
with the 4 blades you don't blow out on fast sharp turns.the boat comes out of the water
quick no matter how many people on the boat and you wont blow out on hard acceleration.
I worked with the tabs and the trim on the out drives but I couldn't get the boat to stop
chine walking I called PQ and spoke with Rick G and he also recommended 4 blades.
I went with 26 pitch 4 blades that brought the rpms down from 4600 to 4450 . I can also keep the boat on plane at much slower speeds .
If you're OK with loosing 1 mph at top end I think you will like the 4 blades better.
#83
Originally Posted by Macklin
Be forewarned, labbing will most likely make you loose mph at cruise speeds. Yeah, you MIGHT pick up a couple of mph at top end, but could loose as much as 5 mph at 3000 - 4000 rpm's. I don't know about you, but I spend way more time at those rpm's than at WOT!
Four bladers are the sh*t. I experienced the same improvement when I switched props on my 272. I am looking forward to trying some 5 bladers on my 340 this spring.
I agree with you though, if you loose at the cruise speed it wouldn't be worth it.
On what do you get out of 4 blades - generally less prop slippage.
#85
Originally Posted by PWRQWST
Macklin
I'm with you after hearing about 5 blades I aslo want to try them.
They say it lefts the bow and that is what I need.
Ahh what the heck, we don't have anything to do in the winter anyway, and you have that nice heated storage.
#86
MACKLIN
Tell me more about your set up. I have a 99 Viper with HP 500's and bravo's labed. I get great hole shot , good midrange but only 76/77 top end at 5100/5200 rpm. Lots of slip. (25%)
I am told the 5 blades will put out more speed but don't have any info from a real test.
What are you running .
#88
Mine is exactly the same as Vyper340's....just different color.
HO's running new stock 28 Bravos. That is what the factory sent on the boat. I had the original ones labbed and lost the 5 mph mentioned above. I did a bunch of prop testing last spring before ordering my new Bravos. The other labbed props I ran, 29 Hydros (hydro labbed) and 30 Bravos (merc labbed), all ran close to 5 mph less at 3500 which is my favorite cruise speed. I am now back to 50 mph at 3500 and 60 at 4000. Sure they are not as fast as the labbed props, but like I said, I spend less than 1% of my seat time at WOT.
That said, I have learned much from Throttle Up during all my testing. The weight of the boat plays into this. The heavier the boat, the more a labbed (thinner) prop blade will flex under load. Thus increasing slippage at cruise.
#89
I have the same results as MACKLIN. I drop 3-4 MPH in the 3-3500 range. I pick-up 2-3 after about 4600 - 5200 with the labs, net I only realize the gains in this range. I went back to my stockers. Remember, they typically remove a lot of cup when labbing, the cup is what is providing the lower-end cruise. My slip is about 12%
#90
New pics for the central IL PQ guys.
Not a PQ though
http://www.offshoreonly.com/forums/s...=1#post1181336
Rich - that is going to be a nice sun pad over those staggered engines. Good place to put my Xmas present this year
Not a PQ though
http://www.offshoreonly.com/forums/s...=1#post1181336Rich - that is going to be a nice sun pad over those staggered engines. Good place to put my Xmas present this year
