which prop Donzi 22zx >
Old 06-14-2005 | 07:48 AM
throttleup's Avatar
Default Re: which prop Donzi 22zx
The torque band of a stock 454 MPI is 4600-5000 RPM at WOT. So at 4200 RPM you are lugging your motor. However with a 22P Lab Finished propeller you should be there. So you need to verify a couple of things.
Confirm Your:
Propeller pitch
WOT RPM, verify your tach.
Additionally I would verify your speeds, via gps and verify your gear ratio.
When testing for WOT RPM you should also be trimmed for speed when recording this data.
Julie
throttleup is offline
Old 06-14-2005 | 10:47 AM
onesickpantera's Avatar
I thought the 310 and the 330hp motors were carbed that ran 4200-4600 and the MPI motors were 365 and 385hp and ran 4600-5000. There was a 310hp MPI motor?
onesickpantera is offline
Old 06-14-2005 | 06:37 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: which prop Donzi 22zx
noboat is right. It is sometimes difficult to remember all the 454 combinations built. The 454 mag mpi is 385 hp fuel injected and the WOT range is 4600-5000 (not the torque band), with a rev limiter @ 5150(if stock). The torque actually falls off slightly after 4600. I would agree, Labbing the 22 Bravo 1 is a good idea. Another great prop is the Rev 4 Labbed at 21P.
[email protected]
bbladesprops is offline
ditty22
07-27-2005 09:51 PM
ditty22
07-27-2005 01:05 PM
c5marine
02-24-2005 02:58 PM
26sonic
Donzi
2
06-12-2004 02:10 PM
purplemoon
05-23-2002 05:55 PM
