Question For Prop Pros >
Old 09-14-2005 | 05:22 PM
Default Question For Prop Pros
Currently Running 34 Pitch 5 Blade Maximus Props. Still Need A Little More Prop. I Been Told That 35 Or 36 Maximus Are Not Available ( Even Do Website For Mercury Has Them Listed ) . What Is The Truth In Reference To The 35 & 36 Maximus Props And What Are My Choices If They Are Not Available. My Props Are Labbed And New Props Would Be Labbed Also
RICKY PEREZ is offline
Old 09-14-2005 | 05:51 PM
Default Re: Question For Prop Pros
Hering prop, if you can get a call back, i have no luck with the return call.
customryder is offline
Old 09-14-2005 | 07:22 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Question For Prop Pros
Yes they are currently unavailable.
We has been making 35 and 36 pitch out of the 34 casting.
[email protected]
bbladesprops is offline
Old 09-14-2005 | 07:43 PM
zt260's Avatar
You can always change gears.
zt260 is offline
Old 09-15-2005 | 08:00 AM
throttleup's Avatar
We can twist the prop up to a TRUE 35P which should pull your RPM down 200. Hydromotive also makes a TRUE 35P P5-X which may work for you. Feel free to call me with any questions that you may have.
Julie
Throttle Up Propellers
727-531-2255
throttleup is offline
buggyride
Baja
5
09-30-2007 01:35 PM
chewymalone
Prop Talk
3
06-04-2007 10:29 PM
nocigarette
Magnum Marine
21
05-06-2007 08:40 PM
Danny_Ocean
2
03-31-2004 08:20 AM
