props for a 42 tiger non step >
Old 04-06-2006 | 11:28 AM
Default props for a 42 tiger non step
boats is closed to bieng finished i will have a strong 750-800 hp what kind of props should i try on a 01 42 nonstep tiger i have imco sc 1.5 drives and stelling boxes. any input would be great thanks in advance
AeroSpeedMarine is offline
Old 04-06-2006 | 03:25 PM
throttleup's Avatar
Default Re: props for a 42 tiger non step
I think you would do very well with the Hydromotive P5-X props. Is it twins or triples? What year is the hull? At what RPMis the peak HP produced?
Julie
throttleup is offline
Old 04-06-2006 | 04:19 PM
My buddy has close to 700 and runs 32 Bravo I's. Goes 82.2
cowisl is offline
Old 04-06-2006 | 04:21 PM
Julie
2001 non step twins and at 5400
i was told that 5 blades dont do well on a non step tiger is that true
Old 04-06-2006 | 07:08 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: props for a 42 tiger non step
I think you will like the Bravo 1 propellers. There are things to consider though. What are your goals? 5 blades do have their place. if the X is high and cruise of the essence.
Lets get a baseline with some type of propeller first. Let us know if we can help in that regard.
[email protected]
bbladesprops is offline
Old 04-07-2006 | 08:08 AM
throttleup's Avatar
I have several clients with 42' Tigers and the 5B propellers have performed well. They simply carry the boat better than the 4B props for overall performance and handling. But lets define your goals and then we can look at the best route to acheive them.
Julie
Old 04-07-2006 | 11:44 AM
im looking for top speed prop but would still like a decent cruise speed ive done the prop calc at 5400 rpms with a 10% prop slip with a 30 at 90-92mph
Old 04-07-2006 | 01:13 PM
throttleup's Avatar
If you indeed have 10% slip then a 5B propeller will not give you more top end. Remember that you need to reduce one inch of pitch if you are calculating slip on Bravo I propellers. So a 30P Bravo I is really a 29P , which would give you a slip of 8% using 91MPH for top end at 5400 RPM with 1.5 gears. So again the 5B propeller will not increase your top end, but will help your cruise speeds and handling. If your 30P Bravo I props are not Lab Finished then you may consider stepping up in pitch and labbing.
Julie
Old 04-07-2006 | 02:52 PM
We have found the Bravo 1's to carry these boats very well. For top speed as stated earlier, I think you'll like the Bravo 1's.
[email protected]
Old 04-07-2006 | 02:53 PM
So I Would Lose 1 Mph Top How Much Gain In Cruise
