cavitation problem >
cavitation problem
cavitation problem
Old 09-11-2006 | 07:55 PM
Default cavitation problem
i have a 24' chapparal villian with a 540hp 502 with a Bravo 1 1.50:1 ever since i built this motor i have had a prop with the prop cavitating right as the boat gets on plane and when its put into a hard turn. i have tried diff props up to a 30" and a 29 that was cupped big time i think now the prob may lie with the hight of the drive. wanted to try a 1" spacer just not sure if thats enough. thanks for your input.
walkintheplank is offline
Old 09-11-2006 | 09:12 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: cavitation problem
What prop do you currently use? More blades may help, spacing may help. Your boat prefers bow lift to stern lift. More blades could also be detrimental. give us some performance numbers and more info to work with.
[email protected]
bbladesprops is offline
Boater0979
Drives and Lower Units
8
08-11-2008 07:08 PM
BIG SLICK
34
10-03-2007 08:15 AM
Penaltybox
8
08-25-2004 06:42 PM
rlavigne
03-15-2004 06:42 AM
SSComp
9
05-11-2003 02:13 PM
