What prop do I have? >
Old 04-09-2007 | 09:55 AM
NoQuarter
Default What prop do I have?
I have a Quicksilver, Mirage 3 blade. I'm trying to determine what size it is! These are the numbers on the prop.
48-13704-23
A41 23P
Is there a website or a tool that I can plug these numbers into to get the details on my prop? I'm thinking about trying a larger prop.
Thanks in advance.
Old 04-09-2007 | 10:26 AM
throttleup's Avatar
The stamping indicates a 23P...or at least it started its life, as a 23P. If you have any performance data post the details here and we can take a look for you.
Julie
throttleup is offline
Old 04-09-2007 | 02:37 PM
NoQuarter
Thanks.
I found out that the prop is: 14 5/8 x 23. My prop is mint and has been balanced (not labbed).
7.4, carb, Bravo 1.
Boat does 61-63 gps and turns about 4600 RPM. However, I have to trim way up to get that speed and the boat is a handful if there is significant waves/wakes.
Is there a better prop for this boat? One that doesn't necessarily offer more speed, but maybe more control? This boat doesn't have trim tabs.
Old 04-10-2007 | 11:32 AM
ENFORCER24's Avatar
From my experiance thats a quicksilver mirage (not a plus)
if your looking for more control i'v heard the 4 blade bravo 1 series props from mercury do well but you loose a couple of mph , on the other end the same size in a mirage + prop would give you a couple more miles per hour but in a 22 foot boat going 65+ would you be comfertable ?
i would but i'm kinda crazy like that
ENFORCER24 is offline
Old 04-10-2007 | 03:05 PM
Pat McPherson's Avatar
A 4 blade prop will give you more control.
3 blade props are typically faster on top but sometimes better control = more speed.
I would try a 4 blade Bravo or Revolution 4.
BBlades or ThrottleUp will have test props I'm sure.
Patrick
Pat McPherson is offline
Old 04-10-2007 | 04:39 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
We indeed can help you with a test propeller should you want to try one. We are just next door in WI.
I like the Revolution 4 propellers on your hull. B1 props can be made to work well also.
Otherwis, Labbing your existing propeller would help in a couple different ways. We could help to get the rpm you need on the top and help some with the stability. We would actuallt turn it into a Plus version. This will increase the bow lift without requiring so much trim. This will keep the gear case more neutral and improve handling.
[email protected]
bbladesprops is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
