HELP with propping/getting bow lift?!?!?!?! >
Old 05-15-2008 | 12:08 PM
A Mirage Plus is the right prop to lift the bow. That boat should run on the last 4 feet of hull when trimmed up. What happens if you keep trimming it up???? Nothing???? Have you tried trimming beyond the trailer stop???? The stop and trim guage pucks may not be set right.
In the pic, you have no rooster tail at all. You should have a little- maybe a foot high and 5 feet long.
Have you checked for a hook in the hull????
Griff is offline
Old 05-15-2008 | 12:33 PM
hook in the hull? yes, i've tried trimming her WAY up! all that happens is i get a HUGE rooster tail, lose speed, and she revs up. nothing else. OK- so a mirage plus 3 blade is what i want. now what pitch? and do i just get a basic prop and call it good, or do i get it labbed? i really appreciate the help!
Freeryd is offline
Old 05-15-2008 | 02:33 PM
Go with a 23 pitch Mirage Plus and get it custom labbed from there if needed. It is the correct prop for the boat. If it doesn't give you more bow lift and more speed, there is some other issue holding it back. You should see 4800-5000 rpms with it and 65mph.
Griff is offline
Old 05-15-2008 | 03:13 PM
Call Brett at BBLADES and try a Mirage 23 as suggested. He has probably setup hundreds of props for a 25' Outlaw. You are only out your time and shipping charges for the prop.
Like everyone has set, you need to turn it up to 5,000 RPMS.
Last year I ended up testing a 25p Mirage and it changed my midrage and top end by so much I bought 2. I bought the test one and purchased a second one to put in the waiting line to get labbed.
1BIGJIM is offline
Old 05-16-2008 | 09:28 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
A 23 M+ Labbed to the correct spec's. is the correct propeller for the boat. We have built countless props for these hulls.
Brett
[email protected]
bbladesprops is offline
Old 05-16-2008 | 11:57 AM
Brett
SWEET!!! Where can I find the contact info I need for you guys?
BILL
Freeryd is offline
Old 05-16-2008 | 01:44 PM
Smile
At the bottom of this post is a link to our web site a phone number.
Thanks,
Brett
[email protected]
Old 05-17-2008 | 06:02 PM
Thanks,
Brett
I'll have to get the info from JB i guess. For some reason it didn't appear on my computer, but it did on his...wierd. Oh well, i'll be in touch. thanks again!
Freeryd is offline
Old 08-13-2010 | 11:51 AM
You right Griff! I have tried a 22 bravo 1 on my baja 25 outlaw and it doesn't like at all. I have gotten a lot of porpoise like crazy at cruising speed with 2 feet chop. I just putting back my 23 mirage +, and no porpoise, better cruising speed, and better top end.
The best propeller for this boat is 23 mirage + with lab finished, nothing else's, that's it and that's all.......for my 2 cents.
Topspeed25 is offline
Old Navy
Prop Talk
22
08-05-2008 04:24 PM
PARADOX
04-28-2008 11:30 AM
perform330
6
03-07-2007 12:27 AM
cstobe
0
04-11-2006 11:06 PM
black devil
4
08-30-2005 03:59 PM
