Where 2 Start >
Where 2 Start
Where 2 Start
Old 07-02-2010 | 02:28 PM
Default Where 2 Start
I HAVE A BAJA 226 WITH A 350 LIL BIGGER CAM IT HAS A 21P ALUMINUM PROP WOT IS RIGHT AROUND 4500 AT 52MPH SHOULD I GO WITH A SS21P OR LOWER THE PITCH TO LIKE A 19P ? SHOULD IT HAVE A FEW MORE RPM'S OR IS THAT JUST ABOUT RIGHT THANKS..................help
boltspeedmen is offline
Old 07-03-2010 | 06:15 AM
Go with a 21 Mirage+. I would suggest a labbed one. Should give you a couple of rpm's.
A.O. Razor is offline
Old 07-04-2010 | 12:03 PM
AIR TIME's Avatar
Thumbs up
+1 on that=21mirage if you get it from bblades he has a swap prop program so if you need to try more than one prop. also if the 21 is near your rpm range he can lab it like said above for full performance
AIR TIME is offline
Old 07-05-2010 | 11:01 AM
ill give them a call thanks alot
Old 07-05-2010 | 02:09 PM
You are very welcome. Tell us about the results, when you have tried some props.
Old 07-06-2010 | 07:52 AM
will do !!!!!!!!!
Old 07-12-2010 | 05:09 AM
Boltspeedmen
Any news on your prop testing?
Old 07-12-2010 | 01:03 PM
I would think you will need a 19" to get the rpms up some. Also, aluminum props flex and loose pitch with more rpm.
Griff is offline
Old 07-12-2010 | 02:16 PM
+1
Suggestion was to lab a 21", so that the rpm's came up to get the bigger top end number. But yes a 19" stock prop sounds about right, too.
Old 07-14-2010 | 02:36 PM
workin some overtime 2 get some extra cash 4 the prop , as soon as i do ill give u a report
