What prop ?? >
What prop ??
What prop ??
Old 07-18-2011 | 03:47 PM
What prop ??
Hi ! I just launched my boat today..for the first time !! The only prop i had in the garage whas a H. p5x And it has problem hooking up .. Its a light mono with airvented padded keel with single 525efi imco standoff + bravo/imco ( High X ) Any suggestions of another prop ? More grip !!!
alfons is offline
Old 07-19-2011 | 06:41 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
We will need much more info. Can you call us?
Otherwise, did the boat get on plane? What rpm could you achieve? What pitch is the prop? Do you know the "X" dimension?
Brett
[email protected]
bbladesprops is offline
Old 07-20-2011 | 03:17 PM
Brett
Yes i did get on to plane ... but i didnt realy hook up . it was a lot of slip ... 26" propshaft is in level with bottom of boat ( imco extensionbox )
alfons is offline
Old 07-21-2011 | 01:52 AM
Probably needs to have a drive spacer installed.
Post everything about your boat. Hull make, drive ratio, and all the info on the prop you tested including pitch, rpms and GPS speed. Without the info, its just guesswork.
Griff is offline
Old 07-21-2011 | 03:22 AM
To have a spacer is the last option ... The hull is a swedish made 28 footer padded keel, Airvented, 1:50 ratio HYDROMOTIVE P5X 15 1/4 X26 i rev it upp to the beep ,and when i get past 4500rpm there is no speedgain just revs ...the prop loses the grip. I am going to beat some more cup. in it today, beacause the hydro i got seams to have very little of that. I have been driving a similar hull with the same X-factor so i dont think thats the problem ...I just need a "better" prop. But what ? 1 small problem is that i live in Sweden and i just dont thake a trip down the road and buy a new one ;O)
alfons is offline
Old 07-23-2011 | 02:06 AM
Brett
Did you get my mail ?
alfons is offline
Old 08-29-2011 | 06:09 AM
Now i tried a couple of props. and the best so far is a stock out of box 30" bravo 1. 5300rpm low eighties ...to much slip !? That i need is a prop with bowlift and lots of grip ..suggestions ! 4 or 5 blade ??
alfons is offline
Old 08-29-2011 | 07:07 AM
Have you tried a Maximus with short tube?
Why is installing a spacer the last option??? If you are too high and can't hook up, you will most likely gain speed by doing so.
A.O. Razor is offline
Old 08-29-2011 | 10:46 AM
I have a 2" spacer now. And i got the same speed with a stock 28" bravo 1 as with the 30"
Little less slip and hit the revlimiter with the 28" tough.... Maybee a modified maximus Will do it.....i have a stock maximus 30 i Can try ...Way to Big and sternlifting for me ....i think...
alfons is offline
Old 08-29-2011 | 04:10 PM
Give it a whirl, it'll never hurt.
You could have the diameter cut down, that should give you less sternlift. So should a shorter tuhe.
