Baja 342 Prop help >
Baja 342 Prop help
Baja 342 Prop help
Old 03-09-2014 | 06:34 PM
  #91
Mine walked right up with 2300.. About 2700+ and started slipping a lil.
But I'm sure I have a LOT less pitch than y'all
nailit is offline
Old 03-11-2014 | 04:35 AM
  #92
how much tab we talking at wide open? I run mine in neutral (level with the hull indicators showing 5) Drives @ 7-7.5 at WOT.. thats 66 all the time 69 once in salt and some rollers.
as i start dropping tabs mine starts to slow
mittens is offline
Old 03-11-2014 | 11:06 PM
  #93
Supposedly you would have to compensate with mor trim while applying tab..
nailit is offline
Old 03-12-2014 | 02:22 AM
  #94
i have tryes dragging tabs, and trimming past my 7.5 point and it does not so anything but slow boat, and props start to break loose.
mittens is offline
Old 04-13-2014 | 06:09 PM
  #95
Bret I have bravo ones 26p on my 342 boss I have a 2000 with 502 mpi in it what should I be running and can u redo mine to make me get more outta them or should I change props? im running 68 69 but would love more
bretconk72 is offline
Old 04-13-2014 | 09:38 PM
  #96
Better off staying put!, your doing good already as we have the lower X!
nailit is offline
