42 Sonic with serious cavitation >
Old 07-27-2019 | 10:51 AM
Default 42 Sonic with serious cavitation
Morning. I recently purchased a 1995 Sonic 42SS. It has a hard time getting on plane. A lot of vibration, cavitation and slip. Also once on plane the slightest deviation in throttle and props lose bite and I slow to a crawl and half to start over. Boat is a 1995. Power is 2 - 540 blower motors with supposed 700 hp. Props - Maximus 5 blade 26 pitch. Drives 1:50 XR's. Not sure if they're turning in or out because I don't know enough about the term. Is top of props turning towards each other " in " or bottom of props turning toward each other " in ". Thank you in advance for any advice or suggestions.
BillyW is offline
Old 07-27-2019 | 11:53 AM
The pic in this ad shows spinning out
https://www.offshoreonly.com/classif...un-o75858.html
Griff is offline
Old 07-27-2019 | 12:33 PM
Thank you for that Griff.
BillyW is offline
Old 07-29-2019 | 04:10 PM
Top of props turning toward each other is "turning in" ………….. Top of props away from each other would be "turning out".
RaggedEdge is offline
Old 07-29-2019 | 05:20 PM
Are the vent plugs in the props or Out? ... and the hub kit is in good shape?
speicher lane is offline
