2007 353 2x496 correct props? >
Old 09-12-2021 | 09:51 AM
OFFSHOREJOJO's Avatar
Default 2007 353 2x496 correct props?
Anybody with 35' formula 353 fast tech what size props work well
2x496/425? Only getting 4000 RPM? Thanks
OFFSHOREJOJO is offline
Old 09-12-2021 | 10:01 AM
F-2 Speedy's Avatar
what props are on it
F-2 Speedy is offline
Old 09-12-2021 | 12:23 PM
I think you should probably be running 28 Bravos. Had a friend with a 353 with 500's and he ran 30 Bravo's.
Griff is offline
Old 09-12-2021 | 07:49 PM
That is what we have but boat can't go past 4000 RPM even trimmed out??
Old 09-12-2021 | 08:30 PM
Does the alarm horn work?
I'm wondering if the engines are in guardian mode?
underpsi68 is offline
Old 09-12-2021 | 08:53 PM
Pretty sure all alarms work but will ask about it thanks! Last marina claimed props that's why I asked correct size?
Old 09-12-2021 | 09:14 PM
Borrow a set of 26's.
How high are you trimming?
....and how long did it take you to get it on the boat stands and off your trailer? #interesting
Keith Atlanta is offline
Old 09-12-2021 | 09:16 PM
Good luck with the prop situation.
But I must ask, how'd you get it on the stands in your driveway?
cheech is offline
Old 09-12-2021 | 10:18 PM
You should be able to spin 28's much higher than 4000 rpms trimmed out at sea level with 1.50 ratio drives and it should have 1.50's.
Any chance the drives are 1.36 ratio?? If they are for some reason 1.36's, you will need to drop down in pitch to 24's or labbed 26's.
If not 1.36's then I'm thinking you may be in 80% guardian mode as well.
Does it get to 4000 rpms WITHOUT trimming up?? What GPS speed are you seeing at 4000rpms?
Griff is offline
Old 09-13-2021 | 05:39 AM
60+ MPH and pretty sure 1.5 drives going to get smaller props to test? Thanks 3 seasons on boat very little trim to get to 4000 rpm just payed a fortune to correct still no luck?
