Eliminator 250 Eagle XP build has started >
Old 08-29-2013 | 09:48 PM
  #51
Randy Nielsen's Avatar
Thanks sdg, that is a major requirement & why I haven't settled on a location yet. I would not be opposed to mounting a couple of cooling fans either if need be. Randy
Randy Nielsen is offline
Old 08-29-2013 | 10:07 PM
  #52
Put some computer cooling fans in the amp rack one inlet one outlet gets a nice cross flow cooling on them. Or gus and electric cooler and mount them to the cool side of it. Lol yes that's a bit overkill for your amps lol but it works well for cooling them off
sdg0080 is offline
Old 08-30-2013 | 07:51 PM
  #53
Looking good!!!
CigaretteSam is offline
Old 08-30-2013 | 09:36 PM
  #54
Randy, you could mount them to the underside of the hatch but wiring would be a pain. If you take the time the amps will fit in the area shown in the pics I posted. Your amps are a couple inches longer than mine but you should be able to make them fit. The computer fan idea is great, I think they run on DC current, would be easy to cut some holes in the inside of the panels for the intake side of the fans? Either way, it's not like your going to be sitting still in that rocket for long...90 +mph on the water will provide plenty of "air cooling" for your system.
IROCDave is offline
Old 08-30-2013 | 10:03 PM
  #55
Hey Dave, that would be a good place to mount them. I will pull those panels & set one in there to see, if they are hidden I won't have to mount the plastic end covers so they will be 20" & 16 3/4". I wish my damn garage was done so I could work on it at night. Oh well, soon. The fans would be more for cooling when beached or tied up the power is to override the exhaust cause I have NO intentions of using mufflers unless drug kicking & screaming. Lol Randy
Last edited by Randy Nielsen; 08-30-2013 at 10:08 PM. Reason: kicking & screaming Lol
Old 09-01-2013 | 11:08 PM
  #56
They will be hidden, and a PITA to get to when the interior is installed. Just make sure you set the manual adjustments where you like before reinstalling the interior. There's no way in hell some one can get a finger on them unless the cuddy seat back rests, bottoms, interior pass through panels and interior panels have been removed. Even then they will be difficult to remove. Ventilation hasn't been a problem on my boat this year. Albeit, the warmest weather it has been in was 90 degrees.
IROCDave is offline
Old 09-02-2013 | 09:34 PM
  #57
COOL, secret stereo Lol I think that's the ticket. Thanks Dave. You know, if the stupid thieves would just UNPLUG the stuff instead of cutting wires I wouldn't worry about hiding everything. Insurance should pay for stolen components but they throw a hissy fit if they have to replace a custom interior. Randy
Old 09-02-2013 | 10:29 PM
  #58
Registered User
Nice project! Looks like its going to come out looking good, just gotta have a plan & go from there. My plans changed a few times along the way but its pretty much exactly what I was looking for. Cant wait to see how the white interior looks all put together.
GTOKILLER is offline
Old 09-03-2013 | 08:35 AM
  #59
wow awesome looking boat
innerrage is offline
Old 10-15-2013 | 08:46 PM
  #60
Thanks innerrage, I haven't worked on it for a while one of the disadvantages of owning multiple boats. Lol I got the interior down to the shop to get redone but that will be a while, I need to get the hull drains fixed then remount the tank so I can get the floor done. I am thinking about doing the floor in 3 pieces so I can access the fuel tank if needed. Also mounting some cross bracing between the outer stringers so the seats will have something solid to mount to instead of screwed to the floor. Randy
