IMP 310 Rebuild/modification >
Old 10-29-2013, 02:50 AM
Originally Posted by Ing
My best friend had a 91 31 IMP he purchased new. These hulls give an amazing rough water ride. Project is awesome. Good luck!
Thanks for the nice feedback
ragman is offline
Old 10-29-2013, 02:51 AM
Originally Posted by Sunrocket24
Nice work!!! Keep up with the pictures!! Viper V10's!! Thats sick!!
Thank you, Much appreciated
ragman is offline
Old 10-29-2013, 02:57 AM
Originally Posted by 315duramax
sweeeet looking boat you got there! only thing is how will the suede hold up to the water and weather?
Thank You The bolsters are made with Alcantara so it will work fine with water. The only downside is that when it rains they get soaked But i have also a set of custom made vinyl covers for when it’s really bad weather
ragman is offline
Old 10-29-2013, 04:13 AM
Here are some fun pictures and (maybe correct) info that I’ve heard from the previous owners in Finland and Sweden
From when the boat was used as a race boat, it was called Cheap Thrills and the driver and team was:
CHEAP THRILLS OFFSHORE RACING TEAM
Ray "Grabber" Grabowski
Steve Fussell
Rich Schieferstein
[ATTACH=CONFIG]511190[/ATTACH]
And this is a picture from when it was a Finnish team who raced with it
[ATTACH=CONFIG]511191[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-finn_race.jpg
ragman is offline
Old 10-29-2013, 04:26 AM
Some pictures from when we lay down a coat of the AWLgrip epoxy primer
[ATTACH=CONFIG]511192[/ATTACH] [ATTACH=CONFIG]511193[/ATTACH] [ATTACH=CONFIG]511194[/ATTACH]
[ATTACH=CONFIG]511195[/ATTACH] [ATTACH=CONFIG]511196[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-35.jpg   IMP 310 Rebuild/modification-35_1.jpg   IMP 310 Rebuild/modification-35_2.jpg
IMP 310 Rebuild/modification-35_3.jpg   IMP 310 Rebuild/modification-35_4.jpg
ragman is offline
Old 10-29-2013, 04:33 AM
The result of when painted it with a special mixture of our gun metal grayish color.
[ATTACH=CONFIG]511197[/ATTACH] [ATTACH=CONFIG]511198[/ATTACH] [ATTACH=CONFIG]511199[/ATTACH]
[ATTACH=CONFIG]511200[/ATTACH] [ATTACH=CONFIG]511201[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-36.jpg   IMP 310 Rebuild/modification-36_1.jpg   IMP 310 Rebuild/modification-36_2.jpg
IMP 310 Rebuild/modification-36_3.jpg   IMP 310 Rebuild/modification-36_4.jpg
ragman is offline
Old 10-29-2013, 08:59 AM
We couldn’t find any vents that looked good so we made our own with some help from a good friend of mine Jon Palmqvist who designed them.
The "home made" vents
[ATTACH=CONFIG]511206[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-30_9.jpg
ragman is offline
Old 10-29-2013, 09:14 AM
I had some problems with the measurements from the blueprint for the headers. It wasn’t exactly the same when we finally received the headers
[ATTACH=CONFIG]511222[/ATTACH][ATTACH=CONFIG]511223[/ATTACH]
So the easiest way to make it work was to modify the heads exhaust ports.
[ATTACH=CONFIG]511224[/ATTACH]
On these pictures I got enough clearance
[ATTACH=CONFIG]511226[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-41.jpg   IMP 310 Rebuild/modification-41_1.jpg   IMP 310 Rebuild/modification-37.jpg
IMP 310 Rebuild/modification-37_1.jpg   IMP 310 Rebuild/modification-37_2.jpg   IMP 310 Rebuild/modification-37_3.jpg
ragman is offline
Old 10-29-2013, 09:22 AM
Started to build new flywheels.
[ATTACH=CONFIG]511212[/ATTACH] [ATTACH=CONFIG]511213[/ATTACH]
[ATTACH=CONFIG]511214[/ATTACH] [ATTACH=CONFIG]511215[/ATTACH]
[ATTACH=CONFIG]511216[/ATTACH] [ATTACH=CONFIG]511217[/ATTACH]
[ATTACH=CONFIG]511218[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-41.jpg   IMP 310 Rebuild/modification-41_1.jpg   IMP 310 Rebuild/modification-41_2.jpg
IMP 310 Rebuild/modification-41_3.jpg   IMP 310 Rebuild/modification-41_4.jpg   IMP 310 Rebuild/modification-41_5.jpg
IMP 310 Rebuild/modification-41_6.jpg
ragman is offline
Old 10-29-2013, 09:25 AM
Amazing work. Looking good.
Crude Intentions is offline
