IMP 310 Rebuild/modification >
Old 11-04-2013 | 09:02 AM
  #51
Last pic for the day. We also had to make new pulleys for the engines.
[ATTACH=CONFIG]511808[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-46.jpg
ragman is offline
Old 11-05-2013 | 09:25 AM
  #52
This is such a cool project. Your doing everything the right way, keep the thread going and updated!!!! I'd love to do half the stuff to my boat!
chazfehn is offline
Old 11-05-2013 | 09:38 AM
  #53
Today there has been some work with the exhaust system. A lot of measuring and a lot of thinking to try to come up with something that’s a little bit different than usual
The beginning of the new exhaust
[ATTACH=CONFIG]511871[/ATTACH]
[ATTACH=CONFIG]511872[/ATTACH]
[ATTACH=CONFIG]511873[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-48.jpg   IMP 310 Rebuild/modification-48_1.jpg   IMP 310 Rebuild/modification-48_2.jpg
ragman is offline
Old 11-05-2013 | 09:42 AM
  #54
Thanks a lot for your nice comments, much appreciated
ragman is offline
Old 11-05-2013 | 12:25 PM
  #55
Very good stuff i envy your shop.
Pliant is offline
Old 11-05-2013 | 01:34 PM
  #56
VoodooRob's Avatar
I was just looking at your photos, you are really knocking this project out with some high end, one-off parts. Excellent machining on the aluminum. Just an FYI, one of your last pics is of your custom exhaust and the rear of the engine showing the crank with the flywheel bolts in it. Make sure to put extra, extra red Loctite on the flywheel bolts on Viper engines. The threads are tapped all the way thru ( you can see in the pan thru them) and oil will leak pass the bolt threads causing you problems. Just trying to help if you didn't know this, obviously your mechanical abilities are far above average.
VoodooRob is offline
Old 11-06-2013 | 02:33 AM
  #57
Thanks for your comments and a lot of fun that you like our shop!
ragman is offline
Old 11-06-2013 | 06:05 AM
  #58
Wow! Thanks for those to kind comments! You made us blush over here
I am aware of that issue with the bolts but big thanks for the heads up. Next time it’s maybe something that we overlooked. Thanks for showing interest.
ragman is offline
Old 11-06-2013 | 07:32 AM
  #59
Found another pic of the vents
[ATTACH=CONFIG]511924[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-30_8.jpg
ragman is offline
Old 11-06-2013 | 09:38 AM
  #60
Threads like this help me get through the winter months
32 Active Thunder is offline
