SSM5 to #6 help
Old 01-21-2022 | 06:09 PM
Originally Posted by Unlimited jd
Several top guns had 6’s on boxes. I had an album stored in one of my old phones of all the ssm 6 guns.
Lil red , how do you fill the wet sumps , there`s no vent .Fill till the overflow starts to get oil in it?
Which leads me to my second question.
I got dry sump inner transom assemblies with these so no resevoir. At what height should I mount the overflow? Any idea?
Aslo what oil in the driveline gimbal?
ICDEDPPL is offline
Old 01-22-2022 | 07:01 AM
yes, fill it from the bottom through the drive, right into the tank
The wet sumps used a tank built into the inner transom plate. You can mount a tank so the level of the oil stays in between the top and second bolt hole in the transom. Gear oil in the drive line carrier, same oil you decide to use in the drives. Torco, amsoil, newer merc gold.
Unlimited jd is offline
Old 01-22-2022 | 06:25 PM
So excited for you it's going to be badass and with the entire new setup you will break 100 easy! So badass
offshorexcursion is offline
Old 01-22-2022 | 08:05 PM
I think I got it figured out , I got some laser high tech $hit going on over here that helped lol
23* fun times .
ICDEDPPL is offline
Old 01-22-2022 | 08:31 PM
BRrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
tommymonza is offline
Old 01-22-2022 | 09:00 PM
Had to think about those pictures for a minute, it looks like the whole assembly was leaning up against the transom and supported by the floorjack on the propshaft, raised up/down tapped around and marked, then i realized you had that custom template to find plumb, center and X, the floorjack was just holding nuetral trim for the laser double check and pics.
nice job, hell of an update !
you take a picture with the template ?
outonsafari is offline
Old 01-23-2022 | 12:17 AM
No trim hooked up so yes you have it right.
The templates are pretty sweet , I`ll snap a picture of the set up later .
ICDEDPPL is offline
Old 01-23-2022 | 08:02 AM
TomFTM's Avatar
Hey Dan if you want wet sump six inner plates with the reservoir, I have a set. I will trade u for the dry sump plates. I have a set of wet sump sixes that were converted to dry sumps that I will be selling . I would rather have dry sump plates. Tom
TomFTM is offline
Old 01-23-2022 | 11:31 AM
Thumbs up
I was going to use my latham bottles but I`d be up for that . clean up the transom a bit .
shoot me an email [email protected]
ICDEDPPL is offline
Old 01-23-2022 | 06:12 PM
TomFTM's Avatar
sent.
TomFTM is offline
