Saber 101
#172
, coming tomorrow, sat its to cold but sunday looks better and next week. already put anti freeze in it last week
, so if I run it sat got to do it again calling for 26 to 30 out over night. sun to wens it 50s again
#173
ok we went out again, we tried 3 drive heights 3''=4=5 3/4'' with no change in handling. still porpoises bad like if the tabs are up at 50 or 60 on the 3rd hop it wants to lift the whole boat out of the water. so its not the drive. seems like balance. I will put sand bags in it one more time. wish I could find a p5 transom lifting prop. but might have to wait til next spring. the 380s bury the azz end so slip is hugh. worst case for me is I put a gas tank in the floor and it works until 1 /4 tank. so I would then need to pull motor remove new tank from bilge
that cost 1500 plus300 in kevlar, and our labor.
, reinstall the kevlar bulkhead closer to the back seat. then move motor 6 to 8'' up front to get the boat balanced. we had 4 guys plus me at the ramp this past weekend. thanks to Knot right Gerry/ Donzi Ken/ Slick stinger Mike/and my dad Boxer Ernie. oops THAT was a secret
. just kidding. but Ernie was worried that I would over push it, so he gave me a brand new lifeline to wear. it was a sad day that the longer drive didn't work, but I felt all fuzzy inside. that I was the lone pilot and would come in have these friend work so hard on this project, have me stay away so I wouldn't get the vest dirty.
. well we have this weekend to see if the sand helps.= gas tank in floor. over the winter I will talk to some guys who redo the bottoms also SABER tomorrow to see if I take the hook out and sharpen the chines and strakes like on a sutphen or cig. I feel this will be a comfortable ride once we figure out the issue. it could be a stearn lifting prop and new tank in the floor. this video Gerry took again but used my hi def recorder so, I need to transfer it to cd/dvd with my pics that Ken took. you can see the boat doesn't look bad with the big tabs way down but, as soon as I raise them it jumps and by the 3rd its a bronco. I will not give up for now. but worst case I'll strip it and put the konrad on a y2k they work great on them, and the steve stepp hulls. cigs. y2k boat ran 94 with 800hp and the ace drive at 3'' they wished they went with 2''. later and thanks guys for the help. you make me feel wanted, not like my wife oops just kidding dear.
#174
#175
I know there is some rocker designed in, but is there hook as well, and if so what for?
#176
The problem is the bottom. Why do I say this without seeing the issue first hand? Because any one that has gone and had a bottom blueprinted or a good straight bottom knows any of the many changes Art has tried would have made moderate differences when tried. When these changes (these haven't been settle) have little effect the bottom is toast.
If it was me, I would throw out the fuel tank (I would have never put the fuel tank were it is,ever.) and put one in the hull between the stringers, pull the engine and drive, flip the hull over and blueprint it. Then mount the tabs flat and have room to move the engine forward if needed.
Artie, sorry to be hard on you but if you want this hull to be safe and work it is the only way to go.
P.S. It would be hard to dump the hull only for any good amount of money due to the dirty laundry aired about it here.
#177
#178
Artie, Gerry told me he was the only added weight up front for
your test ride. He can't weigh any more than 180lbs! I think
Ernie is right, you'll have to add more weight up front than using
Gerry. When doing these tests, think CHEAP! Add the sand bags.
Start out with 250lbs and keep going in 50 lb increases at a time.
Something has to change by bringing your CG forward. Hate to
say it but you will probably need a gas tank change eventually.
It's just in front of the motor and too high causing you to be too
top heavy. Just my 2cents worth. George
#180
Mike....your right, it will probably take all of 500 lbs to calm that
unit down. Look at the Sutphens and Bananas with respect to
where the gas tanks are....tops are not much higher that the
crankshaft line....there's a reason for that. The stock boats are
as low as they can go. George
